S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
jibbguy
If you run the coil vid backwards, you can see the coil being built. He prolly did it this way to shut up the naysayers, but it doesn't help, lol.... Nothing ever seems to ;)
I would agree with those here who believe this overly-vocal skepticism is premature, misplaced, and in rather poor taste; and S1R  is simply trying to get this done the best way he knows how. For those who don't agree with his methods: He probably doesn't care what you think... But do a better job on this project than he is; and chances are he would acknowledge it and switch to your superior method. Until then.....
Anyone else notice the nail is "Galvanized"? Should this not give a different result than a simple "iron" core of the same dimensions would?
Watching those two vids of the B&S popping over... Gives me chills every time i see them. It's like standing on the sidelines on a beach at Kittyhawk a hundred years ago.
Bruce_TPU
Quote from: xbox hacker on July 16, 2008, 10:32:07 AM
It has been updated!! Do you have a link for otto's stuff?
I am looking on page 1, your reply #3, and the picture drawing still appears to be the same.
A post I typo'd earlier and said 5 turn test, it was 50 turn test:
http://www.overunity.com/index.php/topic,1872.msg28062.html#msg28062
That will get you started.  Search user *Otto    50 turn test, and you can read to your heart's content.
Cheers,
Bruce
capacitor70
xbox hacker
Quote from: Bruce_TPU on July 16, 2008, 11:43:19 AM
Cheers,
Bruce
Here it is again...you might need to hit refresh...or put a "?1" (without quotes) at the end of the address in the address bar in your browser, that will bring up the most recent page of the topic....
Any changes you want to make to the coil setup let me know and i will make them, and post to my site. The front page and now this one will have the latest image, as long as you  refresh the browser.
IMAGE:
Bruce_TPU
Hello all,
At 2:26 in the video, I count six (6) actual turns of what is labeled as "main coil".  I know the .pdf says five.
Excuse my poor artwork.  ;)
@ Capacitor 70
Lord of the Rings, and all such threads are about Steven Mark's TPU.  Toroidal power unit.  You would have to read up on it.  I am sorry but it would require far too much time too try to explain here.  Very LONG story!
Cheers,
Bruce
