S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
mhohlecula
hello!!! I'm new in the forum first time i post but have been reading it!!! my knowledge at electronics is rely basic nearly nothing... but i have good imagination ;D. i was wondering a different connection for the s1r transformer as in the schematic instead to connect the lamp wire at the ground connect it at the top of the spark plug so the hv from the coil fires the spark plug creating the bridge for 12v 6 amps or more depends of the limiter used,  ex 60w lamp so like that  hv+12v 6amp crossing the spark gap if the extra amps are the secret, maybe some one tried it already or maybe I'm talking pure bullshit :P any way tanks
lon92
I have spent a lots of my time to replicate the S1R coil...
But, I'm always failed...
Try Plasma Water Spark Plug...
You'll love it!!  ;D
russwr
russwr
russwr
 This is more clarification for those still interested in the S1R9A9M9 mower engine conversion of water in carb as was done in 2008. Simple adjustable brass valve was not used for water line in that back yard test. The 2 people just squeezed the tubing for the amount of water flow to be allowed. The water upside down water bottle had loose cap so as air can bubble upward into bottle as the water flowed downward. LOW amount of water must be allowed to be pulled in by the vacuum of engine at carb top. (So engine not fowl the plug) The idling engine ran on electrolysis for hydrogen gas at spark plug in combustion chamber, aided by water vapor pressure same time. The EGR was not applied as per the previous car engines done, but was supposed to be added with adjustable valve. (Air compressed into water is is 78% Nitrogen aids engine efficiency) The 18HP Briggs engine normally used 4000 ohm resistive spark plug. It has LONG REACH threads that screws in to threaded hole. Nathren and 3 technicians in Georgia only found spark plug of 125 ohms - same threads. At that time they did not know about Champion spark plugs that can come apart. They could not make engine run on 5amps dc since 12-14 volts could not push current through a high value resistance. That's why circuit had added a triple S1R9A9M9 magnetic coils assembly that provided several uses the same time. (1) magnetic field over plug BARE WIRE of 5 turns + SPECIAL 21 turns extends spark time to late negative 38 degrees. (2) 5 amps DC average- Peak 10 amps DC current - same amps for field also as going through spark plug . (3) Timing change done different way since Briggs ignition coil Magnetron is not adjustable as on older car engines turning the distributor. (4) The use of Ohms law E = I X R says can't pass 5 amps through 125 ohms with about 14 volts. About 63 volts required that's not normally available. The wire for high voltage passing through the S1R coils was only bare copper wire. The insulated low voltage wire was SPECIAL wrapped over it. There was cross leakage inductance of higher voltage induced in the low side. This is how the current passed through the spark plug at higher pressure voltage. At that time they did not know to remove resistor from top of a long reach Champian plug and replace it with copper segment, and form a zero ohms plug, or RACING spark plug. Farther down the line, the two output wires go together to plug top. Thre is a magnetic fiel present at combustion chamber that aids the process. There is a "return ground" wire present so as low volts does not return through the casting of engine, as the high volts does. See in video the extention cord "Y" that connects as very long wire from under spark plug to side of plastic tub on side of engine. The separate return line was used on all car conversions with the 400w inverter box. Time in micro/milliseconds is saved by this method and less ohms resistance. Engine started on 12 battery, then battery removed. Engine ran on the under flywheel alternator and DC from diode(s) half wave or full wave DC. The quick positive engine demonstrations Videos 1+2, did not have ANY preventive safety measures as the 10KV was across the battery and dangerous for acid explosion only when battery connected to starter motor. After several non tech people got hurt by acid or burnt shorted wires, they changed the written data on web site so as a duplication wouldn't work . The 3rd video on back porch engine test did not have wire of 5 amps connected to spark plug. The other Youtube videos of "The Smack" testing same engine at Nathren's property also did not have 5 amps wire hooked to spark plug top, but to an alternate resistance load as fan motor. On the first running engine video you can see the 3 power wires coming down from the upper cowl into the plastic tub on side of engine. The heat of the 2008 summer, the heat of engine, had melted the spiral black electrical tape glue so as the heavy tub slides downward, exposing the upper power wires. The S1R coils are in the tub along with other parts such as required accessory spark gap . Nathren's, and tech friends invention was shown working , running on water, but he neglected to say it was self running from the 12 +1 MAGNETS under the spinning flywheel . (The Plus red cable from battery was removed.) That Briggs 18HP had "dual" alternators as originally for one side for 5A for riding mower AC headlights, and 4 A for battery charging. They can be put together for higher amps out, up to 16 amps Full Wave DC, idle speed. Web site shut down. Most of the tech data was on the car conversions using one relay of dual 1.5MH coils per cylinder using the 400W DC to 115vAC inverter source power with one diode output. The 15 relays they had were obsolete- non purchasable . That's why the S1R triple coils was the replacement and using 12v DC instead. There are several US Patents on superimposing 2 power sources together. I use a made up Power supply of ISOLATED secondary side from China 20Khz Inverter open board with voltage doubler , so as the 2 grounds do not interfere. You cannot use the common dc to dc step up voltage converters sold, as it uses 2 of same ground.- non isolated. My set up is about 38V DC , because you need protection from High V., and there are voltage drop losses in series, with resistors + series diode bank , leaving about 20 volts to spark plug for the in series current flow.
