S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
xbox hacker
I built the coil too... i also thought about the dead short on the bare copper, so i separated the copper wire with zip ties pieces...still NADA!!!
Bruce_TPU
Quote from: geovel56 on July 11, 2008, 05:10:30 AM
@ Bruce,
For one, I have built a circuit I am testing, how about you?  Second, an uninsulated BARE WIRE in a coil touching another winding is a dead short... period!  It's not going to DELAY anything... are you a complete moron or just partially?  Why don't you actually read what I wrote intead of running your mouth with inane drivel.
(SNIP)
Now, don't EVER tell me to hang up my Physics books again!  Just be a man and admit you were wrong in stating the delay in a propagated electromagnetic wave could EVER be slowed down enough to account for the effect S1R is claiming.  How absolutely ridiculous!  It's even more ridiculous than comparing how fast an olympic sprinter runs the 100 meter dash to the speed of a bullet from a gun!   The time differential isn't even close!
But PLEASE, build his coil with the uninsulated BARE WIRE windings touching each other as his picture shows, and tell me there isn't a dead short.  The electricity will NOT go around the coil, but straight across the bare wires in contact with each other, so the coiled wire means nothing.  Better yet, test it with your tongue and report to us what happened!  LMAO
Geo
Hahaha!
Laughable explanations!!  About what I expected.  I see that you have already been corrected on the other thread, and are there pissin' people off with your know it all atitude!  LOL
Your problem is that you are so full of yourself you don't listen.  So, for the THIRD time, I never said an opinion on the coil, other than the fact that everyone's time here WOULD BE BETTER SPENT working on Luc and Ossie's circuit!  (The second time I have said that!)
You made a statement that iron could not delay a pulse.  I said this is NOT TRUE.  I said NOTHING about the coil, the short, etc.  Get it???????????????????????  Probably not.
You are "one of the pioneers", REALLY??  Please post the link to your original circuit you "pioneered" or to the youtube video of the spark you "PIONEERED".  You little self important man.  Perhaps I will call you AL Gore the second!  LOL  Did you also invent the internet?
Attributing the cooling affect to the plug as due to the fog, laughable.
You don't listen, and your ego is far larger than your knowledge.  You call me a moron when the truth is you are ignorant and know nothing of what you speak.  You spew out memorized items, and examine things as if you are a lawyer.  I counted 5 people who have already set you straight.  You are a newbie who has contributed dribble.  Just my opinion, you twit!
Why don't you research some of the names I mentioned, read some of their writings, and come up with a better theory of what is happening at the end of the spark plug!!!!  Oh, wait, why do that, I forgot, you already know everything about everything.  Ha!  Nuff said.  Definitely the BLUE pill for you!  LOL
@ All
Dr.Stiffler already made comment about his thoughts on what is happening at the plug.  That is one person you would all do well to listen to and who knows what he is talking about.  Also, Aaron has made comments that make me think that he too understands cold electricity and has come to perhaps a similar conclusion as I.  Study Tesla's "radiant electricity" to understand more.  Especially some of his early circuits to induce this effect.
I will not comment one way or another on this coil, because I have not built it.  But, I have seen strange coil setup's before.  I would comment further, but some would not listen and take is as some sort of endorsement.
Cheers,
Bruce
geovel56
Bruce,
If you aren't the most ignorant person I have ever met, you're certainly in the the top 2  Dr. S didn't correct me nor anyone else... they voiced their opinions as to what they thought is happening, and I voiced mine.  So go build your circuit (if you can) and let's see how well you do with it, otherwise, until you actually have tried anything please shut up.  These threads are full of keyboard scientists of which you are obviously one.
Many of them are good people with ideas to contribute however.  You are not and offer absolutely nothing other than wasted bandwidth.  As for being one of the first invited to Luc's forum, email him and ask him.  I still have the email he personally sent to me with his invitation.
As for reading Tesla and others, S1R's coil, which isn't his either, is very similar (but not the same) to the Tesla Ball Lightening coil setup, only Tesla wasn't a fool and wouldn't make a coil with bare wires whereby the windings were touching each other and even call it a coil, as the net effect woud be a dead short and nothing more than 1 single bare wire.
I don't need to prove anything to you, as you are totally inconsequential and without any redeeming qualities whatsoever.  So keep posting your inane pointless drivel, and continue monitoring the real work of others and maybe someone may show you a bit of charity and build something for you as you probably don't know which end of a screw driver to use.  Three points higher on your IQ and you'd have the mentality of a bare wire coil!  LMFAO at you!
Bottom line, this forum was created by Xbox (who actually does good REAL work and experimentation), to follow the S1R coil (what a joke) and is therefore now a moot point.  He magically "left something out" again, as he has done repeatedly for 3 years.  You are a waste of human flesh and should be recycled!  I see no reason to post on this thread, as it will go nowhere... just like you!
XBOX, keep up the good work on your own and with the rest of us who actually have done real work.  We are all on the right path and will have it nailed down very soon!
Geo
xbox hacker
ok...i am no transformer / coil expert by any means....but i think S1r might have a good idea (even though his coil dont work) Why not make a coil to do what he describes? Jump up the amps on the HV.... Is it possible? I think collectively he should have the brain power to run a engine!  ???
Bruce_TPU
Quote from: geovel56 on July 11, 2008, 03:38:24 PM
Bruce,
Geo
Hahaha!
You are a total waste of energy and time.  The self importance you exude is like a stench from a swamp.
Again you did not listen, (how is this new?) for I never said anything about Dr. Stiffler having a controversy with you.  I hope you read your physics books with more comprehension than you do others posts.  But it is difficult to hear the clarion call of other, when your mind is filled with your own self importance.
I do not care if you have a personal email from the ghost of Tesla, you are still a twit and need to crawl back under the rock that you came out from.  A "pioneer"...LOL  Freakin' laughable if not so pitiful.
I am still waiting to the link to the circuit you "pioneered"?  A video perhaps?   Don't worry, anyone reading your MANY useless arguments in more than just this thread already know you.
Like I said, you are a "blue pill" person.  Enjoy your self made status here.  Just know, that those of us who read it feel the hot air your blowing.
And should you post other "falsehoods" I will be their to point them out and drop your ego size down a few more notches.
Someone disagrees with you and you resort to name calling, etc.  Typical of a self important, insecure person.
I think the readers have better comprehension skills of my posts than you do.
@ All
I would not take Geo's word on ANYTHING working or not working.  Trial and error is always the best way to find out for yourself.  If it doesn't work, fine, you will know it, but NOT because some airbag told you.
Suggested Links to read:
http://www.overunity.com/index.php/topic,5024.msg111751.html#msg111751
AND
http://www.overunity.com/index.php/topic,5024.msg111763.html#msg111763
AND
http://www.overunity.com/index.php/topic,5024.msg111793.html#msg111793
Cheers All,   :D
Bruce
