S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
Really cool of him to show it. A lot of stuff has happened in a very short time soon enough we'll be all putting water in our engines :D.
xbox hacker
Quote from PDF.....
QuoteThe video showed the inverter hooked up, well it is and ant. As many noticed in the
first video. The wires to the inverter was mint to carry the 12 volts to the new coil
only. I didn?t notice it until it was mentioned about on the video, even raised a
question on my part as to how the engine started , then I found out. The battery
charger was supplying the power to the coil . Sorry to do that but it was necessary
because of a reason I will disclose latter
In vid 1 you can clearly see that the inverter is NOT connected to the battery! Their is no "it is and it aint"....IT AINT. Also how would the battery charger supply the coil with power with its not connected to the can either?
hydrocontrol
Quote from: xbox hacker on July 09, 2008, 08:11:16 AM
Quote from PDF.....
Skeptic mode on  ;)
" First video. For the amount of time the engine was shown to run it can easily run on any GAS that was already in the carburetor. Xbox appears to be correct in the observation of how this could work in the first video without the battery hooked up and with only half the battery charger hooked up. Maybe it was not running on water but on gas still in the carburetor.
Second video: Much better from a skeptic side. No Carburetor, at least that is the impression we get from him removing and throwing down the carburetor at the start of the video but with the camera angle you can not tell where the water tube is being inserted.  The water line does not appear to be inserted in the engine intake that the carburetor would bolt too. It appears to be inserted into the air intake on top of the engine so what keeps the water from just running out of the bottle. It does look good that there are bubbles in the bottle when the engine is running but this maybe why the engine does not stay running. Perhaps they should put a hole in the bottom of the bottle to let air in and the water flow out.
Skeptic mode off
Observation.. These guys really need to bolt down the engine to a table. Maybe half hour to throw something together with even scrap lumber. What are we talking here.. maybe 10 bucks of lumber. For someone that just spend a good amount of money on a new engine to do this demonstration experiment you would think that trying to nicely present it on a video would be up there on the list. A cheap starter switch or starter relay would be a nice touch. With just those two improvements then only one person needs to run it and then that one person can do walk around video. A flywheel would also help keep the engine going as most small mower engines need some sort of mass to move like a mower blade or a large pulley. This engine is a bit bigger than most so it may not be as important. How are they avoiding the problem of two sparks for engine cycle ?
ramset
H may not matter [the phantom spark ] with this system   was thinking a 4 stroke may not be negatively effected by this  it didn't appear to blow back through the intake  Chet
Thanks Grandma
boke
hydrocontrol:
He didn't remove the carburetor. He removed the float bowl from the bottom of the carburetor.
The float bowl is filled with gas from the gas tank. It has a shutoff valve that stops the gas flow when the bowl is full.
With it removed there would not be enough gas residue to fire the engine over more than a couple of cycles.
The air intake for that particular carburetor is on top. He does appear to be putting the water line into the air intake.
