URGENT! WATER AS FUEL ENGINE DISCOVERED AND PATENTED
Started by tishatang, July 13, 2008, 01:56:39 AM
tishatang
@Luc
Thanks for the hard work and observations.  Am I correct in that you and Sabori did not see the green ball directly, but only after looking at the video frames?  Evidently it is too fast for the eye to capture?  My feeling is that the external green ball is a nuclear event.  Maybe some atomic particle is driven out of the cylinder at high speed and collides with another particle in the near external field?  To me, it seems the piston goes down regardless of the external green ball?
I would think it would be better to contain the green ball within the cylinder chamber.  The metal of the engine would act as a shield against radiation.  Would the detector you are going to build reveal nuclear radiation?
Maybe this is the reason for the large coils around the cylinders, to contain and direct the energy in the direction of the piston travel?  The coils are energized only during the firing stroke in the Papp patents.  As you develop your test setup, you may at some point energize a coil around the cylinder and see what happens.  Also, there is a superimposed high frequency in the megahertz range.  The coils and high frequency are mentioned in the later engine Papp patent.  I do not have the ability to print out the patents where I am, so I can not study them in detail.
Tishatang
gotoluc
gotoluc
Quote from: tishatang on August 15, 2008, 10:05:16 PM
@Luc
Tishatang
Hi tishatang, sorry for the late reply. Yes, they say that they don't see the green light ball when looking at the spark and can only be seen on the video. It would seem it is too fast for the eye and mind to capture.
What I think is going on, is the spark event creates a disturbance in our time continuum which opens a hole and that is what we see as the green light. So I don't know if we can contain that green light event since it may not be from this dimension. I think the coil around the cylinder is to create a strong magnetic field within the cylinder which has an effect on the gases. I will test this later with my sealed clear Lexan piston and cylinder test engine.
For now I am back working on my lawn mower engine with gasoline fumes and water vapor tests. I think we can creat the GEET effect right in the combustion chamber which would be an easy mod for regular car engines to cut down fuel use by 50% or more. Once I'm done testing and sharing that I will resume the build on the sealed clear Lexan engine.
Luc
gotoluc
NETIKS
Green Light ...Maybe its aperance of the x-rays
all the best
-netiks-
