What do you think about my electrolyser? Is more efficient?
Started by Magnethos, July 15, 2008, 07:55:59 AM
Magnethos
This is a possible desing of the new cell using 20 plates.In the pictures there are only 2 plates.
Magnethos
A new video where I?m showing the same experiment. I only get big bubbles instead a lot of little bubbles. The electrolysis is clearer. 9 Volts 550 mAmps 2 plates.
http://www.youtube.com/watch?v=dYiGsMbHPCs
In this experiment where I obtain big hho bubbles, my ac/dc adapter gets very hoy in less than a minute. Why? Whe I made the other experiment using the same materials that I use in this experiment, my ac/dc adaptor was very very little hot and I used it a lot of minutes.
NerzhDishual
Hi Magnethos,
IMHO, your experiments are very interresting.
This let my think about the DallasGoldBug electrodes.
This guys manages to get some gas with distilled water
and DC current only (not pulsed and 'resonant' current Meyer-way)..
http://www.overunity.com/index.php?topic=4302
Actually, IMHO again, electrodes shapes seems to be one of the keys of
very efficient electrolysis. Viktor Schauberger made amazing things
with water and shapes. What about the pyramids?
Best
Nolite mittere margaritas ante porcos.
Magnethos
@Nerzh
Thanks for the info. Yes, the electrodes are very important to get more or less hho gas. When you said the piramid I though in Kanarev low energy electrolysis
http://www.guns.connect.fi/innoplaza/energy/story/Kanarev/electrolysis/index.html
As you can see in the picture, the Kanarev seems to be like a piramid. I have seen a video of his electrolyser and is awesome the amount of hho gas that he is getting:
http://www.youtube.com/watch?v=E4Q9gggJ3XA
Viktor Schauswerger was also a genius using water as energy. I have read a few about him, but he said that the motors of today are explosion motors and explosion means destruction. The universe works in a implosion fashion, so implosion means construction. He designed implosion engines but I haven?t seen any plans or picture of his motor, but I heard that he could get infinite energy from the implosion motors.
I haven?t heard about DallasGoldBug but I have seen some of his videos and yes... the electrodes are similar to my electrodes. One guy said to me that I could get more hho gas using the same energy, but using more plates. I only use tap water with no electrolites, no resonance and only DC @ 9Volts 0.5Amps. I have to build one device using 20 plates at least... if I can get that bubbles using only 2 plates, the amount of hho gas that I could get using 20 or 50 plates will be awesome. I can get hho gas from distilled water too.
I think that in 1 cm I can hold 5 to 10 plates. So, in 50 cms... I can put 250 to 500 plates... That sounds very good!!! The bad new is that the plates corrodes. I have seen a video where the electrodes that used a guy doesn?t corrodes and the electrolysis was clean with no ugly products in the water, because he used MAGNETIC stainless steel.
Here you can see the amount of hho gas that I?m able to obtain using only 4.5 Watt
triffid
When you use more plates and the same energy you get more bubbles because you have more surface area.That is untill the voltage falls below 1.25 volts for each cell( for the brute force electrolysis you are using).With your 20 cell setup and the same power(9volts I believe).I dont think you will see bubbles.Because the voltage falls below 1.25 for each cell(about.45 volts).Now pulse that same voltage and you will get bubbles.Also when something gets hot you are wasting energy(ie.using too much).Happy experimenting.Triffid
