this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
nitinnun
the pyramid does not have to be mathematically perfect, to sufficiently perform its energy activity.
in fact, the pyramids energy activity, is extremely forgiving of errors.
even if 50% of the pyramid were bent out of shape, than that 50% should still have 50% of the energy effect (magnetic current would be the biggest sufferer, however).
most of the pyramids energy effect, depends on the surface area of the 4 sides. the edges are just where the 4 sides end.
the biggest function of the edges, are to seal in energy. to keep the energy flowing from peak, to middle, to base, to outside, and back to peak.
nightwynd
Now what the heck does: User 'hartiberlin1' has exceeded the 'max_questions' resource (current value: 100000) mean? I?ve gotten that message a bunch of times now and it won?t let me post?irritating.
@wile_coyote7 - Thanks :) It's a bit of a hobby...I'd run the full version of 3d studio max...but Vista blows goats and won't run it very well at all. So I'm stuck using GMAX - it's a free program to download (Free lisence) just google it if you want to play around.
Okay, so I modified the pyramid a bit...I was a bit confused about the 60/40 split...did you mean actual surface area? or 60% of the overall height of the pyramid? They are two very different things...
The pyramid I've drawn here is done to the same exact dimensions as the ones in Giza... 440 long on the base, and 280 overall height. The ones in Giza were measured in cubits, but gmax does not distinguish units. It can be inches, centimeters, millimeters, or kilometers - it's all the same.
I'm a bit surprised about constructing it out of rosin paper - seems like it'd be flimsy to me. And how would you go about putting the layers of paper together? Elmers glue? If that's the case, why not just build it out of foam-core and save yourself about 4 hours of tedious labour? (come to think of it I've got about a dozen 3'x4' sheets of foam core just sitting around doing nothing...) Would foam-core be a viable material to use? If so I'll begin cutting fairly quickly.
Anyway - here's the updated model: I made the copper/aluminum split at 60/40 of overall height as it was easier and didn't require me to do scads of math to calculate the proper triangle size. I also moved the peak coil down near the base of the peak. The picture itself is a screen-shot of what i'm looking at.
Nightwynd.
Need motivation? Read: http://www.lifeaftertheoilcrash.net/
Sincerely - nightwynd
nitinnun
i wanted to bend 20 layers of rosin paper in half, to make 100 layers.
then cut a triangle out of those.
then put 2 layers of duct tape over that.
that many layers of rosin paper, plus duct tape, plus metal wrapping, would be sturdy enough.
you can use any non-conductor, in place of rosin paper. though i'm not sure of the energy properties of foam.
foam tends to build up static electricity. that could somehow mess things up.
you are not even supposed to use magnetic metals in the pyramid. or else they will prevent the pyramid from aligning with magnetic north or something.
amigo
I'd like to toss some random thoughts in and see what the rest of you think, please excuse me if they are incoherent. :)
I somehow have a feeling (call it a hunch) that the geometry IS an issue and that the size DOES matter. Long story short, I read Lakhovsky's book Secret of Life fairly recently and concept of "oscillators everywhere" is still fresh in my mind so here's my deduction. The pyramid looks to me as an oscillator, forget the antennas and wires leading to, and including, the capacitor.
We have an open loop oscillator built from an inductor made from two metal plates (copper and aluminium) and a capacitor in the form of a dielectric between them. Because I said that the geometry is an issue, the oscillator will only work at peak efficiency when tuned to the right frequency matched by the inductance and capacitance of the circuit.
If we look at the Great Pyramid as an example, the builders could've made it any size, and in those proportions, but I think they chose THAT size for a reason - namely to match some (unseen) source of oscillation and resonate with it.
Yes, other sizes of the pyramid might work, but they would most likely match harmonics and not the fundamental oscillation, if/when the LC circuit is tuned to them, again meaning that not all dimensions will work but only proportionate few.
Now off on a tangent, the pyramid with an antenna on the top reminds of something that has been done elsewhere - in Radiestesia.
I remember long time ago testing designs of copper pyramids that had sort of an antenna (coiled copper wire, with a tip pointing upwards and the other end connected to the apex). IIRC, these pyramids have been known to control the "bad" energies and convert them to "good" ones. It is very simply to prove this using a pendulum and anyone can test this easily if you're into dowsing.
Further more, it did not even have to be a real pyramid - a mathematical pattern of numbers between 1 and 9 laid/etched on top of a square copper plate with an antenna as described above in the center would do the same job. Heck, even the same pattern on a piece of paper has some effect, but we are digressing here too far now...
Any thoughts?
nightwynd
Quotei wanted to bend 20 layers of rosin paper in half, to make 100 layers.
Not to be a flamer or anything...but that math just doesn't add up. 20 layers folded in half would give 40 layers....unless you folded it 5 times, but then you're not folding it in half. I don't really think you'd even be able to fold 20 layers of that stuff - all your cuts would be all screwy. Also be wary with duct tape - some of it is electrically conductive. You may be better off sticking with Jeanna's idea for packing tape.
On a side note: I hit the local hardware store today to see about some materials - they gave me such a blank, vapid and stupid stare when I asked for copper foil, or a thin sheet of copper. He seemed genuinely stumped, like he'd never even thought of the possibility... (they breed 'em dumb around here - I'm from elsewhere :P ) Also checked out acrylic plastic (took him a bit to figure that out too...after a minute he was like "oh! you mean plexiglass?" I so wanted to face-palm myself before smacking him upside the head.) The acrylic was LUDRICOUSLY expensive... over $60 for a 4 foot square, 1/4" thick. Disgusting... I'll have to shop elsewhere.
Too bad about the foam core - can anyone confirm that it has static issues, or other conductive properties? I did a quick google, but came up dry. I'll do a bit of shopping on the weekend to see if I can source some cheeper acrylic - clear stuff would be easier for presentations and such if this thing works as intended.
@ amigo - I'm not sure exactly why the egyptians built the pyramids the way they did...but there are multiple pyramids scattered around the globe that are different sizes and slightly different shapes. The ones in Giza are a bit different however - they are situated to TRUE NORTH, not magnetic north. They are also located in the dead center of the earth's landmass, neatly dividing the planet into quarters. Also, a little research into pyramid geometry gives results calculating to 1.6180...PHI.
Okay, I'm pooped, and I'm goin to bed - g'nite all, I'll be back tomorrow.
Nightwynd.
