Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
ResinRat2
OK Everyone,
I had to clean up my work area before I took these videos so everyone doesn't know I'm a SLOB! lol.
Attached are a couple of views of the reactor. You can see the four electrodes 2 zinc on one side and two different sized tungsten/carbide electrodes on the other. You can see the two fuel cells. The plastic one is the 0.9 volt one and the metal one is the 3 watt job. The small one is running the fan and the larger one is regenerating one of the zinc electrodes at the same time the other zinc electrode is being used to produce hydrogen. You can also see the oxygen vent tube I placed straight up and secured it so in case of overflow it will go into a jar. This allows the two sides of the reactor to equalize their liquid levels and vent oxygen at the same time.
The fan is running at what must be max speed, that's why I used the small fuel cell to run it. I don't know its power rating (fan) and I don't want to burn anything out. I will add more load in the future and perhaps use the large one to run things.
So we have a working unit. Generating hydrogen and oxygen at the same time and also regenerating the zinc. All with no power input and a good power output (relatively speaking).
I will now be doing long-term testing so unless something drastic happens you won't hear much for a while.
Thanks for your interest.
ResinRat2
hartiberlin
Hi ResinRat !
Very well done !
Please keep at it and let us know
the outcome of a longer test.
How much did you pay for the 2 fuel cells
and where did you buy them ?
What is their power rating ?
Many thanks.
Regards, Stefan.
ResinRat2
Sorry the videos are so short. For some reason I am having a very difficult time posting longer ones on this site.
My computer was down for two weeks because it was attacked and destroyed by spyware, so I don't have all my software loaded, and windows movie maker is still missing. I can't edit the views and lengths of videos.
So I am posting the best I can. I know, I know, I need to buy a better video camera. Sorry about that right now.
ResinRat2
Quote from: hartiberlin on October 13, 2007, 09:47:21 PM
Plexiglas fuel cell: http://www.fuelcellstore.com/cgi-bin/tornado/view=Item/cat=61/product=40
Metal fuel cell: http://www.fuelcellstore.com/cgi-bin/tornado/view=Item/cat=24/product=43
They are not cheap, and there is the disadvantage of this system. I will now be working on designing a platinum coated mesh that will be installed directly within the cell itself. The hypothesis I have is to use the hydrogen on one side of the reactor, and the oxygen on the other separated by a permeable barrier (filter mesh or filter paper) that will use the hydrogen and the OH- ions in the electrolyte solution to produce a current. So the entire unit will be sealed and no gas or water vapor would escape. It would just be a box running cold and sucking the heat from the air around it. Producing electricity from the temperature differential.
This was Dingus Mungus' dream idea. A sealed box that produces electricity.
Thanks everyone for your interest.
