Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
ResinRat2
HTH,
This system already runs cool, it doesn't need any cooling. I want it to absorb the heat from the air around it.
jcims
Quote from: ResinRat2 on November 25, 2007, 07:28:47 PM
HTH,This system already runs cool, it doesn't need any cooling. I want it to absorb the heat from the air around it.
The radiator just increases the thermal coupling to the ambient air...in most cases we use it to cool something, but in this case it would help pull heat into the system (e.g. by more efficiently cooling the air around it).  Just like an air conditioning coil, for example.
ResinRat2
Quote from: NssB on November 26, 2007, 11:42:22 AM
Like a heatsink in reverse :)
Hi NssB,
Such a device would draw energy from the system and how much energy does a pump draw? I don't think it's really necessary here. I ultimately want this unit to be as efficient as possible, and if I can just use materials that do the job instead of machinery, then to me that would be the most desireable.
hansvonlieven
G'day Dave,
Perhaps a stupid question, but I'll ask it anyway. I don't mind making a goose of myself if new knowledge comes from it :-)
Is there a temperature difference between your zinc and tungsten electrodes and if yes, how much?
Greetings
Hans von Lieven
