Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
Super God
Hey, don't worry, I always find that things wind up working better for me in the long run when it is delayed a bit.  Just keep up the good work and don't give up!  Best of luck to you, Dave!
-Brian
>9000
linnard
Hi Resinrat 2
Use Silver solder to connect the tungsten electrodes.
Linnard
ResinRat2
Quote from: linnard on March 20, 2008, 06:48:32 PM
Hi Resinrat 2
Linnard
My lucky guess, that is exactly what I am doing. Thanks very much.
Tacmatricx
Hey RR,
Had an idea today about the cell operation after researching flooded cell lead acid batteries for power installations:
http://power.tycoelectronics.com/Family.aspx?FID=f8dc88ff-9d6b-4601-92ca-d823fcb79120
Basically most of these types, especially the non spill gel batteries and even the newer fiber mesh types can be easily damaged by draining the cell too quickly. Reducing cell life because of lead crystal grid growth.
What you're essentially doing in all of your designs is shorting out the cell directly... adding a resistor load (trying to run a heating coil for instance) could reduce the cell gunk buildup? I would add a variable resistor and start at high resistance and go from there while monitoring output and cell cleanliness.
I'm working on an extremely simple regeneration switcher for you using a high value resistor (1megohm), a zener diode to control the charge switching, a large capacitor to control the timing and a two low voltage reed relays to do the actual switching. Basically built for someone with no electronics background and is easy to understand.
BTW: I still thinnk that your electrolyte balancing tube might overflow depending on your pressure... It might be easier to build the cell to fit the gas generation... i.e. make the volume of your H2 chamber twice the size of your O2 chamber and have simple pressure switches to switch the cell off at a certain pressure. Working on a simple pressure switch using syringes, springs and aquarium tube.
Cheers,
Chris
ResinRat2
Hi Chris,
Wow, great. I am open to your ideas. I appreciate the effort and the input. Post them here for all to see.
Thanks
