Dingus Mungus
I can't wait to see how much wattage you can
pull when the reactor is fully loaded with tungsten...
It's going to be quite an interesting month!
;D
ResinRat2
Hi Dingus,
I wanted to give you an update on this experiment.
I wanted to confirm that the zinc regeneration is taking place so I removed both electrodes from the solution, cleaned them all off thoroughly, then put the whole thing back together except that I now have 13 tungsten/carbide rods connected directly to the zinc portion of the zinc/aluminum electrode.
The gas started to come off the tungsten and I could see some coming off the zinc. Within a minute I held the cell up to the a light and I could see threads forming on the zinc electrode surface. There is definitely zinc replating going on. WITHOUT added power. This is great news.
When your reactor arrives I will modify it so that I can use this zinc/aluminum electrode method. I now have two fuel cells. One is small (0.95V) and the other is larger (2.5V). I think I will add them both to the reactor. I will tap the small cell power to slowly "push" the reaction in the forward direction to increase the output of hydrogen. The large cell I will use for power collection. I will see what series of small devices I can run with it.
This is a bit off the original ideas but since I have two fuel cells I figured I would try using them both to see how much power I can get out of this thing. Hopefully your reactor arrives within a day or two. I am eager to work on this.
Thank you everyone for your interest.
Trump
ResinRat2
Changed posting,  Hopefully  when you get your reactor things will really get exciting. Seems you are getting closer and more enthused every day ResinRat2. Keep up the good work.
Trump
ResinRat2
Hi Dingus,
This morning I looked at the cell and it looked like it stopped giving off gas. I didn't have time to look it over much but I don't kinow why. It looks ok, no strange color or precipitate or visually obvious problems. I will look into it after I get home from work.
This looks like it is a side project that needs to be investigated further. I guess I won't modify your reactor (when it gets here) yet. I will use the wiring as I stated earlier.
I will use both fuel cells, but the smaller one I will use for zinc regeneration. The larger one I will use for pure power collection; hooking up what devices I can power off of it.
Sorry the news was not good, but that's the way research goes. It might just be something simple.
Thanks everyone for your interest.
ResinRat2
Hi Trump,
You changed your posting so I changed mine.
Have a good day.
