CLaNZeR playing with a Buoyancy and Gravity idea
Started by CLaNZeR, July 24, 2008, 02:18:59 PM
zapnic
good job man
but if you but magnet in that tube with water and top wheel magnets
like it's holding down and release right spot
hhhmm will it work? ???
AlanA
Hi CLaNZeR,
I just shaw your wheel.
How do you get the wheel spinning? What is in the tubes?
I think the wheels need some push to startspinning.
Alana
Michelinho
@CLaNZeR,
You look like you have fun building projects. For your tubes inside the water, you could use the car shock absorber idea, restrict the flow of water around the tube by using a round soft rubber gasket attached at the center of the tube cap, one way the cap would back the gasket and the other way it would bend to allow more flow. Car shock absorber use 2 one way valves of different size but tougher to implement.
I'm working on a clay battery, messy and still low power but fun.  ;D
Having fun is part of life.
Take care,
Michel
AlanA
Hi everybody,
in the past I thought about buoyancy of air in water (like many others)
I think the key is to get a bucket of air from outside at the bottom of a tank full of water in this tank.
Does anybode out there knows a solution. It would help really.
