Mysterious Resonant Circuit
Started by EMdevices, July 24, 2008, 10:04:51 PM
eldarion
Quote from: pauldude000 on July 28, 2008, 02:34:02 PM
If what I consider is correct....... (that possibly SM's driving unit was the actual source of OU, and the TPU itself merely amplified the effect...)... that would explain much.
I nearly had the same reaction...and I think you are 100% correct here!  The same thing should apply to the Boyce device.  Use three of these, somehow triggered in sequence around the periphery, and the available power should increase dramatically.  Hmmm...I seem to recall something in one of the SM documents explaining the operation of the TPU very similarly to this!
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
aleks
Quote from: eldarion on July 28, 2008, 02:50:26 PMUse three of these, somehow triggered in sequence around the periphery, and the available power should increase dramatically.
Why not just try to connect one into another after rectifier bridge? I wonder what happens on the "output" end of the existing unit if you use two or more batteries with higher overall input voltage.
eldarion
Quote from: aleks on July 28, 2008, 02:56:33 PM
Definitely an option.  I was just trying to tie in the various clues on rotation and gyroscopic action...maybe the FTPU operated the way that you suggest?
-- Thomas Paine
aleks
Quote from: eldarion on July 28, 2008, 03:04:35 PM
Three or more toroids on a single chassis may create a really "pronounced" gyroscopic effect, especially if relatively high power is running around the cores (not just 1W). Beside that an open TPU may "house" 4 of such stages in those boxes, all connected via lamp wires in a "funky" fasion like openTPU is a big core while it's just an "artistic" way to interconnect parts of the device. And of course, considering geometric relation of these boxes, this may create a "rotating" magnetic field simply because units are "powered" in sequence and the non-rectified output is sinusoidal.
Frederic2k1
Please, can anybody explain to me, why in EMDevices' circuit the transistor is driven in a non-convential way
First when voltage is applied the cap next to transistor loads through 100 Ohm resistor and then when it reached 0,7 Volt the transistor is conducting. For me this is a convential way of using a transistor...
