SM expose'
Started by HEYDUDE, August 02, 2008, 10:44:58 AM
turbo
Quote from: Grumpy on August 21, 2008, 09:39:29 AM
I have come to be suspicious of the intentions of anyone that constantly asks for more details and schematics without showing effort along the way.  These actions appear as attempts to acquire information.
Ditto.
c0mster
@HeyDude funny you should ask.
Here is what I am working on now. I won't go into detail yet but I will release a vid soon.
turbo
Hey cOmster  that is looking great.
I have tried something like that yesterday.
Only i used permanent magnets.
My goal was to replace the disk with a pancake to see if it would put out more voltage and lower amperage.
Marco.
innovation_station
@ marco guess whos coil i am building next ......
i suspect it will be a larg one......
the last time i built one of thease it returned 16 w ......in 1 zap as i recall
ist
giantkiller
Another CU/steel/FE setup.
Digital vom across battery in normal circuit shows 13v. Digital Ameter shows 2-8 amps, fet gets real hot!
I hook in the diode bridge.
I put 4khz in with 555. When rise hits the whole circuit shows 6mhz.
The leds light, Resonant rise thumps on like a bull in a china shop (no rise, just jacks on), Vom shows 1(overload) @ 1000vdc setting, Ameter @ 10a setting shows -1(overload), Fet has only body temp.
Scope shot? Solid band across screen of 21v sine wave 6Mhz. Almost twice the voltage in.
Now the dvms can be confused. But the same setup drops in amperage consumption as I add an output circuit.
So when resonant rise hits the consumption goes down. Sounds like wireless power transmission. I need to hook in analog meters to see. Since they are mechanical they should not respond to spurious fields, right?
Looks like some type of wireless and the battery is charging. How do I see this? The ameter waffles between .02a and -1(overload). Then after about 5 mins the ameter locks on -1 and stays there. The rise already set at 5 seconds. The ameter is responding to a slower effect than the short time of the Rise kicking in. Almost like the time the battery is being topped off. Did I say kick?
I remember seeing Eric Dollard / Bordarlands video transmitting power with the LMD/TEM setup. Did anybody see this too? The transmitter wasn't single wire.
--giantkiller. Minature Wardenclyffe?
