New member: A Newman motor replicator.
Started by Michelinho, August 02, 2008, 06:16:27 PM
Michelinho
Hi all,
The brush holder for the coil brushes is adjustable +/- 45 degree from TDC. It can be adjusted with the motor running. It is on a round wood bushing sitting around the shaft bearing. The commutator blank spaces are 1.5X the width of the brushes and should not short out.
The 2 magnets are N48 1"X1" Neodymium with 87.6 lb of pull. The clearance between the magnets and the coil is 5mm. The rotor is made of carbon steel with a weight of 2lb.
To get more torque, beefier magnets would be needed but also a thicker magnet wire coil setup. As is the motor runs with 460VDC and 0.034A after tuning the motor/brushes setup. I don't have enough lead acid batteries to go that high in potential.
I will make a small alternator for the present motor and see if I can get as close to COP=1 as possible.
Take care,
Michel
P.S.: It will be easier to build a new motor than to mod this one. I don't feel like unwinding about 50,000 feet of awg31 magnet wire...
the_big_m_in_ok
Michelinho said:
...I did my first replication last year and my second one is just done and getting ready to build the axial flux alternator to be coupled to it....
>>Hi all,
Michelinho has interesting photos unloaded to the forum, but my question is:
Is the schematic available for uploading or otherwise being rendered in ASCII keyboard notation?
Newman's patent, or application, #WO8300963, had a basic schematic in the drawings.  I had thought of trying to replicate it inexpensively with a 20" box fan arrangement similar to his patent/application or the Muller motor/generator.
Newman's work is shown on  http://www.free-energy-info.co.uk  (in .html)
--Lee
the_big_m_in_ok
