Antigravity effect based on a principle of counter-rotating magnets
Started by pasi1, August 06, 2008, 06:23:37 PM
giantkiller
Quote from: Omega_0 on August 14, 2008, 02:52:09 AM
Ya, rotating magnetic fields should produce gravitation anomalies. (No that's not proven yet). :)
You can always use gears to step up the rpm, no need of high rpm motors. Say, use a 100:1 gear with a 1k rpm motor to get 100k rpm. (Or a series of gears of lower ratios)
Place a weight on different positions around it and measure weight changes.
Now how to detect weight changes ? You'd need a very very sensitive balance and the whole thing should be in a vacuum chamber, else air will interfere and can produce lift.
Difficult, but possible to experiment.
Oh yes it is sir...
Searl.
--giantkiller. If it runs itself it does way more!
giantkiller
Quote from: giantkiller on March 05, 2009, 11:06:28 PM
Oh yes it is sir...
Searl.
That is Searle effect.
Interference of 2 or many fields. Keely + Tesla = Hutchison.
You all have seen the Searle generator spinning. Just put a loop of Romex right out of the box on top and tap the power off of it.
--Jian K'lar.
nave
im very poor in english , please read Carefully
you notice that  counter rotating  magnet not efficient  for levitation and anti-g ... you need electrostatic , longitiudinal wave(scalar wave) , longitudinal standing wave ....  for this you need alumium(hamel use this metal in his antigravity mashine for electrostatic charge or longitudinal wave between magnets in form of pipe shape)  or coopper (john searl device use this metal)
and neodemyum(searl use this) or cobalt (diploma device use this that in alnico magnet )  and plastic or dielectric i don no for what reason.
aluminium or coopper  -- neodymium or cobalt  --  - plastic   --- magnet ---
you notice that in crystul structure of cobalt and neodymium both are hexagonal  ( searl told : neodymium layer serves as a source or reservoir of electron charges that are drawn out by electromagnetic induction  or radient energy )   and victor grebennikov ( hexagonal shape emit longitiudinal wave , de broglie wave in Nest bee , notice that one wing over another create levitatin(to longitiudina wave) )
you notice that leedskalnin in make of coral castel ( told: for levitation you must give frequency to magnet ... pmh(perpetual motion mashine)give dc pulse to pmh and  Creation longitiudinal wave(when to defferent magnet pole face to face create longitudinal (just like counter rotate current bifilar coil tesla not normal bifilar coil tesla that two current identical direction)   // may bunch of pmh and adjust to creation standing wave or different form of Interference between longitudinal  wave but in identical frequncy) ....
all of this feature is in alnico magnet
counter-rotating magnet ==== rotating magnet = frequncy  and make longitudinal wave and Interference between longitudinal wave(standing wave longitiudinal(gravity)  and magnet  and aluminium )
moving charge create magnetic field  = http://www.icestuff.com/~energy21/hamsear.htm
stan deyo levitation device ( Interference between longitiudinal wave ( in form of standing,stationary wave )
tesla coil create longitiudinal wave then two tesla coil in (identical frequnecy)  and  if  may make standing wave in some area creat gravity.
and in your mind that It works with longitiudinal wave(scalar wave) ... if you know what does frequency created, you able to levitate , make gravity , teleport , spoon bend ( just like hutchison effect)
two electromagnetic pole or wave  create longitudinal  and two or more longitiudinal wave (in some condition ) create gravity or anti-g . but  may magnet be needed for this (kesh foundation said : magnetic field create gravity  http://keshefoundation.org/new-horizons/fields/217-principle-of-magnetism
http://keshefoundation.org/new-horizons/gravity
http://keshefoundation.org/applications/space/gravitational-technology/140-gravitational-positioning-spacecrafts-propulsion-systems
and plasma , may ingnition , They say emit longitiudinal wave ( http://www.tesla-coil-builder.com/FlatSpiralSecondaryPlasmaBall01.htm )
plasma with longitudinal in some frequency  cure disease
tesla coil in various frequncy  (electrotherapy)
longitiudinal scalar wave :::    http://rationalwiki.org/wiki/Scalar_wave#cite_note-14
nikola tesla longitiudinal wave (((((((
http://journal.borderlands.com/2010/the-broadcast-power-of-nikola-tesla-part-1/  ( Gerry Vassilatos — from Borderlands (Vol. LII, Number 2, Second Quarter 1996) )
"Tesla was sure that this new discovery would produce a completely new breed of inventions, once tamed and regulated. Its effects differed completely from those observed in high frequency alternating current. These special radiant sparks were the result of non-reversing impulses. In fact, this effect relied on the non-reversing nature of each applied burst for its appearance. A quick contact charge by a powerful high voltage dynamo was performing a feat of which no alternating generator was capable. Here was a demonstration of "broadcast electricity".
Most researchers and engineers are fixed in their view of Nikola Tesla and his discoveries. They seem curiously rigidified in the thought that his only realm of experimental developments lay in alternating current electricity. This is an erroneous conception which careful patent study reveals. Few recognize the documented facts that, after his work with alternating currents was completed, Tesla switched over completely to the study of impulse currents. His patents from this period to the end of his career are filled with the terminology equated with electrical impulses alone.
The secret lay principally in the direct current application in a small time interval. Tesla studied this time increment, believing that it might be possible to eliminate the pain field by shortening the length of time during which the switch contact is made. In a daring series of experiments, he developed rapid mechanical rotary switches which handled very high direct voltage potentials. Each contact lasted an average of one ten-thousandth second.
Exposing himself to such impulses of very low power, he discovered to his joy and amazement that the pain field was nearly absent. In its place was a strange pressure effect which could be felt right through the copper barriers. Increasing the power levels of this device produced no pain increase, but did produce an intriguing increased pressure field. The result of simple interrupted high voltage DC, the phenomenon was never before reported except by witnesses of close lightning strokes. This was erroneously attributed however to pressure effects in air.
Tesla made electrical measurements of this projective stream. One lead of a galvanometer was connected to a copper plate, the other grounded. When impulses were applied to wire line, the unattached and distant meter registered a continual direct current. Current through space without wires! Now here was something which impulses achieved, never observed with alternating currents of any frequency.
Analysis of this situation proved that electrical energy or electrically productive energies were being projected from the impulse device as rays, not waves. Tesla was amazed to find these rays absolutely longitudinal in their action through space, describing them in a patent as "light-like rays". These observations conformed with theoretical expectations described in 1854 by Kelvin.
In another article Tesla calls them "dark-rays", and "rays which are more light-like in character". The rays neither diminished with the inverse square of the distance nor the inverse of the distance from their source. They seemed to stretch out in a progressive shock-shell to great distances without any apparent loss.
Most imagine that the Tesla impulse system is merely a "very high frequency alternator". This is a completely erroneous notion, resulting in effects which can never equal those to which Tesla referred. The magnetic discharge device was a true stroke of genius. It rapidly extinguishes capacitor charge in a single disruptive blast. This rapid current rise and decline formed an impulse of extraordinary power. Tesla called this form of automatic arc switching a "disruptive discharge" circuit, distinguishing it from numerous other kinds of arc discharge systems. It is very simply a means for interrupting a high voltage direct current without allowing any backward current alternations. When these conditions are satisfied, the Tesla Effect is then observed.
The asymmetrical positioning of the capacitor and the magnetic arc determines the polarity of the impulse train. If the magnetic arc device is placed near the positive charging side, then the strap is charged negative and the resultant current discharge is decidedly negative.
Tesla approached the testing of his more powerful systems with certain fear. Each step of the testing process was necessarily a dangerous one. But he discovered that when the discharges exceeded ten thousand per second, the painful shock effect was absent. Nerves of the body were obviously incapable of registering the separate impulses. But this insensitivity could lead to a most seductive death. The deadly aspects of electricity might remain. Tesla was therefore all the more wary of the experiments.
He noticed that, though the pain field was gone, the familiar pressure effect remained. In its place came a defined and penetrating heat. "))))))))
Etown
Hi guys,
I'm new on the forum and was happy to see this thread. I have been interested in natures forces for a long time and recently have been reading a tesla book that sparked some thoughts. I thought up some similar devices to what you guys are talking about. Although for different reasons. I was more interested in the magnetic cogging that is produced in this design for potential power generation.  I was wondering if any of you would have any suggestions for some pulse coil designs to get this baby spinning so I can start experimenting with different power generation coil designs. Any help would be greatly appreciated.
Etown
