Antigravity effect based on a principle of counter-rotating magnets
Started by pasi1, August 06, 2008, 06:23:37 PM
ramset
I have to say
I do like Franco's gyroscope
its very Nice
and now you have the next page....
8)
no charge  :D
Thanks Grandma
verpies
Quote from: ramset on March 11, 2016, 07:29:34 AM
Well it [the option ] goes away after a certain time has passed
if you do This [keep written lines shorter and cycle your lines instead of run on]
it will stay over on left side of the Page and all can read with out putting on
sneakers and running back and forth.
The overunityresearch.com does not have this problem because it resizes pictures.
The ultimate solution for a webmaster would be to resize the inline images to the width of the client's window.
Is that so difficult to do?
ramset
Yes
It must be almost impossible ...since Tinsel has Begged for a decade [at least]
to do this ??
seems Over unity will come first ??
then maybe Stefan will buy the delux package ?
Thanks Grandma
citfta
Some of the other forums I belong to will not let you up load a picture if it is over a certain file size.  Is that hard to do?  It seems like the easiest solution but I am no web site guru so I don't really know.
I just saw at the bottom of the reply window there is a limit on file size but it is 7000KB.  Can't that be reduced to a more reasonable size?
e2matrix
Quote from: ramset on March 11, 2016, 08:29:36 AM
Yes
to do this ??
I've told TK and have mentioned it many times here.  The solution is simple.   User Opera web browser for viewing here and click the 'Fit to Width' button (mine is in bottom right corner) and everything fits to the width of your screen without changing the text size.   It seems other browsers should have this option too - I haven't really looked into it but Opera has been an innovator since way back in introducing new things that usually end up in  other browsers eventually.
The other thing is that if you have a newer large monitor AND your screen resolution is set quite high like 2560 x 1440 it is rarely a problem with any browser.  If you are still using 800 x 600 or even 1024 x 768 you will have that problem often.   As much time as most people spend on their computers it is worth the upgrade if you don't have a larger screen and video that supports it.
