Squared Newman motor, Can it works?
Started by Magnethos, August 09, 2008, 05:57:50 AM
khabe
The same but upgraded version,
See rotating outer back iron, flange for and plastic housing/frame helps to fix windings from on one side (fixed to face bearing holder)
Regards,
khabe
Magnethos
Very interesting info. I don?t know why people do always the same experiment... and again and again...
They can build the motor with other configurations and see what happens.
Personally, I want to mix bedini and newman motor.
khabe
And simple Axial version. I would prefer X-mode wound coils (A-a = 180 degrees) (for all models ;-) - not parallel like original Newman does but OK,
When X-mode wound then also multipole rotor is possible and why not the same number of coil pairs ;-)
You can now compare what kind of version has more useful winding area  ::)
It seems that Sphere does, then comes long radial  :-\ For axial I prefer also back irons - just two nickel-iron disks on both sides
as close to windings as possible. Or rotating soft iron wheels  :o
Regards,
khabe
Magnethos
The last seems to be the best one. I thought in a similar motor as you as drawed. But the magnet are like in the bedini motor, something like this
