Novel Approach to Bessler Wheel
Started by Vortex1, August 11, 2008, 10:29:06 PM
Vortex1
Here is another partial internal view of the machine. It does not show the outer rim of the casing wheel or the catches that help to recycle the flywheels.
To summarize again,
1.Gravitational energy is stored in angular momentum of the flywheel as it rolls down the incline rails on it's small axle.
2, The rails are fixed to the outside world and do not rotate with the casing wheel. The tilt angle is adjustable.
3. Angular momentum is transferred to the casing wheel when the flywheel exits the ramp.
4. There is a torque "step up" based on "flywheel outer diameter" to "casing wheel inside diameter"
Electrically, the flywheel can be modeled as a capacitor that "charges" as it rolls down the ramps. The flywheels energy (torque) is discharged into a step down transformer ("casing wheel inside diameter" to "flywheel outer diameter"). The casing wheel acts as another capacitor which accepts the charge (torque). This increased torque hopefully can recycle the prior flywheel already on its way to 10;00 in the catches so provided.
