Bowman Permanent Magnet Motor Replication 2008
Started by CLaNZeR, August 12, 2008, 10:54:14 AM
eavogels
Quote from: CLaNZeR on August 14, 2008, 08:53:30 AM
Does anyone know what happened to Douglas Mann who claimed to have a Bowman Motor working and detailed his construction in detail at this link
Yes, I do.
He still does experiments with free energy.
Eric.
eavogels
Quote from: CLaNZeR on August 14, 2008, 08:34:18 AM
Is there info anywhere else on the second design?
Some info is here: http://fdp.nu/shared/manager.asp?d=files\Bowman64
(often this overunity.com is responding so extreemly slow. Do you experience that as well?)
CLaNZeR
Quote from: eavogels on August 14, 2008, 12:40:07 PM
The problems were not the bearings but the aligning of the shafts. Aligning the gears at the back, the long rods AND the magnetic gears in front gives problems if the fitting is not 100%.
The first thing you can do to find out if you are on the right track is checking if you can give one of the gears a spin and see if all rods keep spinning some rotations. If so, you can start testing with the actuator. Otherwise you have to align. Since you use CNC, you probably have a good alignment from the beginning.
Hi Eric
I want to use Brass nuts and washers but they are not here yet. But I wanted to check the alignment of the Gears and used some Steel nuts for now.
Here is a small video showing the Gears and their looseness as such.
I also popped on the magnets I had just to get a feel for the magnet interactions, I was surprised.
http://www.overunity.org.uk/bowman/CLaNZeRPlayingwithBowmanMotoPart1.wmv
Cheers
Sean.
CLaNZeR
Quote from: eavogels on August 14, 2008, 12:44:56 PM
Yes, I do.
Eric.
Did he never re-build another Bowman and show a video? I find this very surprising.
Shame really
Cheers
Sean.
CLaNZeR
Quote from: eavogels on August 14, 2008, 01:17:25 PM
Today Overunity.com has been really slow, but seems okay at the moment  ;D
Many thanks for the link will go take a look!
