Turn a satellite dish into a parabolic dish
Started by infringer, August 25, 2008, 12:42:44 AM
onthecuttingedge2005
Quote from: kampen on March 26, 2009, 10:09:52 AM
@ All,
Looking/searching for a small circulating pump, mustbe heat-resistant because I intend to circulate oil in my Parabolic Solar Heat Absorber. Any advise/help is welcome.
Thanks in advance.
Hi Kampen.
You'll get your greatest efficiency by building an efficient wave guide, one that traps the heat and radiation the longest within the wave guide it self, Aerogel has a 99.98 efficiency at trapping heat and bouncing it around so you may want to look into that for making a wave guide block, one side of the Aerogel can be mirrored to help trap other frequencies of radiation as well.
If you need some engineering advice on building a Radiation Wave Guide Trap just ask and I will see about looking into parts for you to assemble.
I see that you are using a oil based medium to conduct heat? there are better Heat Moderators that could increase the efficiency even higher.
I could show you how to make a Ultra high efficient Heat trap but the only draw back is the very expensive materials needed, they are not cheap at today's rates of scientific instruments.
Jerry ;)
The perfect energy production system
1. uses no moving parts.
2. converts all band gap energies to usable energy.
3. made of ultra light material.
4. made ultra transparent for optimal radiation transmission.
5. utilizes Radiation traps or internal mirror wave guiding to reuse trapped radiation within the confines of the solar photovoltaic optical cell. (recycles its own radiation near 100%).
these are just 5 of the attributes to a ultra efficient power production system. no motors or engines could keep up with such a system.
on a secondary thought besides the one above, it may be possible to use a magnetically confined ultra positive ion plasma to attract negative Electrons to a capacitive surface trap that conducts the Electrons away from the +++ Plasma attractive source, this is just a thought and nothing more.
Jerry ;)
kampen
kampen
