Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
zapnic
hello
i was allways think that TPU is like metal detector "upside down stuff"
http://en.wikipedia.org/wiki/Metal_detector
turbo
Well Steven said there were engineers that measured the local field strength.
I often wonder what equipment they used, simply because HV lines that close to the demonstration HAVE to show up on good equipment.
Steven said they never found anything, so pherhaps somebody has to go up there and measure it again :-\
Even on a spectral analysis from a loose piece of wire, the powergrid is dominant visible.
Pherhaps the engineers conciderd it normal and their equipment was unable to detect VLF or even ELF waves.
M.
zapnic
hello
i second thing
positive lighting  hhmm i believe that was sm little story about tesla
and positive lighting is 10*  stronger  then negative lighting  and only 5% all the lightins are positive  why?
then i have to  find out if there is a similar thing positive lighting and inrush current "vacuum tubes"
let see i have the find some books or maybe internet  will help me
bye
Antimon
It should be clear that the devices will be so big that you cannot imagine to capture ELF and VLF waves, for example from power lines. No chance with the size of stevens devices. The next proof is that the field lines must be in an exact direction, that means a little movement of the coil means no power any more and that means a little angle, not a turn over. You should think about that.
A.
wings
Quote from: zapnic on February 03, 2009, 07:26:27 PM
hello
i second thing
bye
this can help
http://en.wikipedia.org/wiki/Corona_discharge
