Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
otto
Hello all,
@EM
do your "job" with tubes. They are amazing!!!
Dont even think you know how tubes are working. Today I wrote to a good friend a message and I told him it looks like tubes are recievers for "cosmic rays", aether or call it what you want.
Still no tubers here??
Otto
sparks
     I like it when Eric Dollard puts a vacuum bulb powered up by two nodes which have no voltage inbetween them but do represent conductors upon which dielectric fields can tereminate.  He then shows that inside that altered vacuum state within the bulb there exists a potential over ground.  He charges a capacitor one end hooked to a sink and the other end close to the bulb.  Try doing that with a mosfet.  In a wire the electrons may go one way but the space inbetween them gets altered alot faster than those little buggers which have MASS can move.
Energy inside a capacitor is stored in the form of altered vacuum.  It has shit to do with electrons.  When we charge a capacitor we condense the vacuum or create mass.   The field between capacitor plates is relative to all other types of vacuum.   A blackhole is condensed vacuum or full of energy.  The core of the Sun holds the atmosphere together because energy is continually condensing in it's core.  The sun doesn't run out of fuel it runs out of energy stored in the form of mass in it's near field to condense in it's massive neutron core.  The more energy confined in a field the more gravity.  This is a cooling process of our Universe to create mass from a totally energetic or radiant field.  In one neutron of one atom there may have existed at one time a complete planet.  The proton still has some spin to it's surface and hasn't cooled enough to become a neutron lacking the mass of the neutron.  Meanwhile the neutron is able to hold protons together because of the weak atomic force which is actually ENERGY DENSITY relativity.  Tempic field arises from this EDR.  Cold electricity gravity etc.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
tsl
Quote from: sparks on February 17, 2009, 10:39:31 AM
     ...When we charge a capacitor we ... create mass....
That should be obvious, charging a capacitor mean storing energy and energy=mass, so yes it should be a heavier capacitor  ;D
wattsup
@otto
Regarding the 5vdc to the tube cathode, I think if it was applied via a "vibrator" tube, there may be a way to return it back to source. I think it was EV Grey that used one with his tube.
I have tubes, even a tube tester but right now my plate is full with the study of coil and ring results that will eventually help also, since tubes will still need coils.
@EM
Push on. The math is above my head but I trust your explanation. Go for it. You will probably need some Litz wire for that antenna. Hendershot had collectors and control coils also.
@all
I had prepared a rather long post but will not post it. I just have one question regarding the ring. I made a new ring with Litz and two outer coils that is working fine. The ring has 1050 strands of 46awg and when looped in three, this gives 3150 wires to catch energy from the control coils. One CC is wound full length and the other about 25 degress over the ring and they are connected in series. The good thing about this particular wiring is that I am getting the best results from 1 volt up to 6 volts and at each volt increment, I am getting more output. I feel such an attribute of the coiling is essential if the device is to work with gain, it has to work just as well at low voltage as with higher voltage. Most coil schemes I test work either well at low or high but not accross the board.
The question is this. My Litz wire is straight.
When the outer coil imparts energy to the ring, Lenz's law will make it so the more energy the ring gets, the more it will repel more energy from the control coil. Even though the ring has three turns and this sort of equals a bifilar set-up, what if the ring was also like a twisted pair. Would this cancel the rings field and enable the control coil to impart more energy???????
We are fighting with Lenz's law all the way. Imagine any air coil with a twisted pair secondary connected bifilar then with a one strand primary of x turns. Would the secondary act like an energy funnel that creates no repelling action on the primary. That is going to be the key.
My next tests will be with one regular ring and one twisted pair ring for comparisons to see if I can push more energy into the ring.
The wires in the ring of the FTPU could be a multi-bundled twisted pair even though they look like a standard wire. "Wire is very important".
Hmmm I wonder if @otto's ECD used a tightly wound twisted pair type ring, maybe there would have been more results.
Added: Even if we are already on the next page I thought I should add a photo of my current coil just to give you guys the real idea.
starcruiser
try a neo near the coil to see if that increases transfer
Regards,
Carl
