Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
wattsup
@GK
Thanks for the idea but this will only double the load which is something that would not be feasible at this point. The question of if the LED that is a diode only works in one way or both ways is to find out from @EM and his working device if there is in fact any current directionality or if the ring can work in both directions depending on the potential direction permitted by the LED.
EMdevices
LED works either way,  I tried using a diode bridge to get DC and then had a series choke to make sure the resonant tank was not disturbed, but it didn't work quite as bright,  I guess I need some good germanium diodes like in the video links posted above by Tito. I'll be absent for a while again.....but I'll be back
EM
turbo
EM did you switch off the mains power to see if it came from the house wiring??
If it then stil lights maybe it is tapping in some strange phenomena like earth waves or something  :o :o :o :o
M.
wattsup
Thanks @EM,
That's what I wanted to know. It says alot about about the loop being able to light that diode from both sides.
The lowest voltage LEDS I have found for my loop is 1.4volts but I measured my loop and it is fluctuating between .05-.25 volts so I have to find some smaller LEDS. I just got the components and will also try the smaller circuit from Titos referred vids.
But just to let you know, I am always pursuing the other end with the FTPU build and all so hopefully from both sides I can learn more about the TPU, what it can and can't do, etc.
