Towards Realizing the TPU
Started by poynt99, September 03, 2008, 08:46:35 PM
0 Members and 16 Guests are viewing this topic.
BEP
Please note as the earlier pdf link describes somewhat - this coil is inherently less coupled to the core conductor. Also be it understood such a coil is famous for very low output voltage. The solution is found if you understand voltage is not only induced by increasing field from the conductor being monitored but also by increasing rotation and frequency of the monitored current. Also understand the coil is only sensitive to the complete rise and only a small portion of the fall time of the monitored signal.
This alone would provide some conversion of sine to a more DC output.
Then there is the use or non-use of magnets.
Consider the orientation of the magnets on all with magnets except the OTPU along with the orientation of the magnet used to start the early TPUs. Unless he had unusual magnets the poles were pointed to the vertical central axis.
This tells me he was using radial magnetic fields.
Now the only way to cause a radial field with CCs wound as shown is to always have adjacent coils bucking. You then just rotate the bucking point around the circumference in a way that no coil is ever off. There is your virtual rotor. The OTPU uses the same bucking with the red wires except the bucking points include fields concentrated by applied magnets.
The circuitry then would be nothing more than a racetrack circuit.
pauldude000
@BEP
You may well have something here......
The drive circuitry would then be current, not voltage, dependent and could be low voltage high current pulses. 1 joule over 1 second = 1 watt.... the same joule over 1 microsecond = 1 megawatt (Energy/Time=Power). It does not matter whether these pulses have a "gap" in between them. This would explain the "AC or High Frequency characteristics of a DC arc".
If you were to space the pulses properly, you would have 1 megawatt pulses flowing through the field generation coil. If carefully balanced using amperage verses voltage pulses, then the output would drastically increase in the Rogowski coils......
The control coils would then not only be the generation coils, but could be used to monitor the field, and thus control current pulsing.... brilliant!
This may actually work!
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
pauldude000
Quote from: metatorian on June 10, 2009, 04:40:57 PM
[0345] "Energy is not Bound by the Space-Time Lattice."
This is an important distinction and relevant to his concept of quintessence as a frequency. He seems to be saying space-time and matter is not a fundamental system, but Energy is.
[0346] "Thus as the EPR experiments suggest the existence of energy separate from matter and thus separate from the three dimensional space time lattice, it is interesting to find that experiments suggest the existence of free energy in a continuum separate from space time and matter to produce the effects of quantum teleportation."
So I would guess the total Energy includes "hyperdimensions" in a holistic scale of reference and possibilities such as those credited to Tesla in the alleged Philadelphia experiment with the rotating magnetic field, a SUPERTPU, if you will.  :D
I will go out on a limb, and risk looking the nut.
What I am stating, in a nutshell, is that all energy IS the "system". His described space-time matrix is nothing more than a latticework of stored energy potential.
What people refer to with terms such as "zero-point energy" is free energy not coalesced into either the space-time matrix or into much larger "particles", and is somewhat unusable by any other source, as it is a background energy with no available difference to equalize, in other words no "ground".
Particles are made of the same energy, and so are the "quasi-particles" such as photons. This energy however is MORE BASIC in nature than photonic "light", as is currently thought by many.
This concept also explains the emergence directly from space-time of short-lived unstable "virtual" particles as well as spontaneous stable particle formation. It is merely energy release and conversion of already present potential.
All "Energy" is either locked up in and/or proceding from as well as eventually returning to, the "space-time matrix".
What we are describing is in effect the "Aether" of old. No surprise, as it requires little imagination to understand that the current space-time understanding did not ever replace the Aether concept, but merely restated it.
That is why "space-time" has physical properties to begin with. It truly no more explains action at a distance than did the old Aether concept, it merely gives finer detail.
Paul Andrulis
giantkiller
The 60hz system we have today is comprised of Conduction and kinetics. Too bad. The controlling forces of that time thought you have to push electrons. Tesla's solution enabled that for long distances. A real half-assed fix. But he had to pry dollars from the idiots somehow.
But!
If Telsa had his 100% way the we would be kinetically transfering atomic pressure upon a transformer at a distance with no current flow and through resonance. Each transformer would become a baby Wardenclyffe and then shock the aether in resonance with the return magnetic force and not conduction through a conductor.
Oops! You wouldn't need a grid. The wheelworks of nature would be our device.
--giantkiller. Silly humans...
tsl
Quote from: BEP on June 11, 2009, 01:14:15 PM
.... The solution is found if you understand voltage is not only induced by increasing field from the conductor being monitored but also by increasing rotation and frequency of the monitored current. Also understand the coil is only sensitive to the complete rise and only a small portion of the fall time of the monitored signal.
Now the only way to cause a radial field with CCs wound as shown is to always have adjacent coils bucking. You then just rotate the bucking point around the circumference in a way that no coil is ever off. There is your virtual rotor. ...
Hallelujah
Remember my posts?
