Bedini's Free Energy Generator Replication
Started by oouthere, April 04, 2005, 03:10:57 PM
oouthere
I ordered "Bedini's Free Energy Generator" booklet and after looking at it, the idea seems too simple.  Basically it's a single pole, multiple coil set-up ran in series to boost the voltage.  The only oddity is the battery is connect about 160 degrees to the motor and then 160 degrees to the generator.
Has anyone seen this set-up work for over unity???  I looked at the failed test results on www.theverylastpageoftheinternet.com but that is not what Bedini stated to build.  He simply pulsed the motor on/off for one second at a time.  Nor did he have the generator motor pulse out of phase as the directions calls for.
Thanks,
Rich
joe
Hi Rich,
Could you be a little more precise about this" (The only oddity is the battery is connect about 160 degrees to the motor and then 160 degrees to the generator.) Cause i don't understand that part.
Thanks and have a  good week!
Joe
oouthere
The unit has a commutator with one rotating pick-up of about 160 degrees and a common feed to the commutator that hooks directly to the positive side of the battery.  The pick-up rotates and contacts the brushes of the positive motor input and then contacts the energizer (generator) output.
Otherwise, this is a typical generator being turned by an electric motor.
Rich
joe
Thank Rich  I see what you mean now!!
I have started to build my new "4 coils" motors a few weeks ago (bedini's replication) and could not get the machine go really well with the set up of 4 transistor on each coil. So last week end i decided to try an old transistor from an old computer monitor and to connect the 4 coils on that transistor. ( transistor #2sc2625- 450v. 10a. 80w.) It has working really nice, i have let it go for about 6 hours and i took the battery voltage at the beginning (12.54 v.) and when i stopped it was at (12.42v) These are the only measurement i did that day cause i did not have the time to work longer on it. But what i can say is, it is very encouraging. So this week-end i will try to go a little step further.
Joe
vectortan
Does that booklet you have, have designs that look similar to his patent or is it and offshoot from that?
