Major Mathematical Solution of Newman's Theory!
Started by kmarinas86, September 09, 2008, 10:09:04 PM
kmarinas86
BY KMARINAS86
September 9, 2008, 9:18 PM
voltage*charge is a given for a set of batteries with some voltage and charge capacity.
[(dm/dt)*q] = [voltage * charge] = Electrostatic Potential Energy
[(dq/dt)*m] = [current * magnetic flux] = Torque of Magnetic Field
While voltage*charge is normally referred to as the energy in the battery, we are instead interested in the energy of the magnetic field as derived from interactions which happen during circuit operation.
We'll see if the magnetic field's energy comes from battery chemistry alone.
force = energy / distance
force = power / velocity
force = (change in power/change in time) / acceleration
linear charge density = charge / distance
linear charge density = current / velocity
linear charge density = (change of current/change in time) / acceleration
applied voltage = voltage drop due to capacitance + voltage drop due to resistance + voltage drop due to inductance
applied voltage = charge/capacitance + current*resistance + (change in current/change in time)*inductance
applied voltage = linear charge density * (distance/capacitance + velocity*resistance + acceleration*inductance)
linear charge density = charge / distance = applied voltage * capacitance/distance
applied voltage = applied voltage * (1 + velocity*resistance*(capacitance/distance) + acceleration*inductance*(capacitance/distance))
velocity*resistance*(capacitance/distance) + acceleration*inductance*(capacitance/distance) = 0
velocity*resistance*(capacitance/distance) = -1*acceleration*inductance*(capacitance/distance)
velocity*resistance = -1*acceleration*inductance
-1*velocity/acceleration = inductance/resistance
-1*power/(change in power/change in time) = inductance/resistance
Therefore, as (change in power/change in time) decreases, so does power.
This kind of power is a type of power that cannot exist without changing. It is called reactive power.
A short circuit will produce a low resistance/inductance. This will mean that (change in power/change in time) is high relative to power.
A Newman motor has a very high inductance/resistance (i.e. L/R time constant). That means for a given change of power, the power is already larger. When power changes from the off state, a given change in power in a given time would mean a larger power output. This means that there is power already built into the device before the system even turns on.
For a given voltage, the change of power per change of time is:
change of power/change of time = voltage * (change of current/change of time)
The reactive power is voltage drop due to inductance, which is equal to:
reactive power = voltage drop due to inductance * current
reactive power = inductance * (change of current/change of time) * current
reactive power = magnetic flux * (change of current/change of time)
Which applies even if inductance is not constant. The formula "inductance = change of magnetic flux / change of current" does not apply if inductance itself changes.
Inductance can be thought of as two ways:
1) The relation between a change in applied magnetic flux and the current it induces in some random material.
2) The relation between the current in a material, and the magnetic flux that it produces as a result.
Therefore:
(change of current/change of time) = reactive power/magnetic flux
change of power/change of time = applied voltage * reactive power/magnetic flux
Thus:
power/[applied voltage * reactive power/ magnetic flux] = -1*inductance/resistance
power*magnetic flux/[applied voltage * reactive power] = -1*inductance/resistance
power*magnetic flux/[reactive power] = -1*inductance*[applied voltage/resistance]
power*magnetic flux/[reactive power] = -1*inductance*impedance
power/[reactive power] = -1*(inductance/magnetic flux)*impedance
power/[reactive power] = -1*impedance/current
power/[reactive power] = -1*applied voltage/current^2
Now what exactly is this power?
As stated earlier:
force=energy/distance
force=power/velocity
force=(change in power/change in time)/acceleration
So power=force*velocity, but what else does equal?
First we must understand that:
angle=distance/radius
and equivalently:
distance=radius*angle
Thus:
force=(energy/radius)/angle
force=(power/radius)/angular velocity
force=((change of power/change in time)/radius)/angular acceleration
Now we know that:
power=force*radius*angular velocity
[force*radius*angular velocity]/[reactive power] = -1*applied voltage/current^2
reactive power=[force*radius*angular velocity]/[-1*applied voltage/current^2]
reactive power=-1*[force*radius*angular velocity*current^2]/[applied voltage]
We remember that:
reactive power=voltage drop due to inductance * current
So:
voltage drop due to inductance * current=-1*[force*radius*angular velocity*current^2]/[applied voltage]
voltage drop due to inductance=-1*[force*radius*angular velocity*current]/[applied voltage]
We recall that:
voltage drop due to inductance = inductance * (change of current/change of time)
So:
inductance * (change of current/change of time)=-1*[force*radius*angular velocity*current]/[applied voltage]
inductance * (change of current/change of time)/current=-1*[force*radius*angular velocity]/[applied voltage]
We already know that:
acceleration/velocity=(change of current/change of time)/current
inductance * acceleration/velocity=-1*[force*radius*angular velocity]/[applied voltage]
And since:
angular velocity=velocity/radius
inductance * acceleration=-1*[force*velocity^2]/[applied voltage]
inductance * acceleration * applied voltage=-1*[force*velocity^2]
inductance * (acceleration/force) * applied voltage=-1*[velocity^2]
(inductance/mass) * applied voltage=-1*[velocity^2]
-1*(inductance/mass) * applied voltage=[velocity^2]
sqrt(-1)*(inductance/mass) * applied voltage=velocity
i*(inductance/mass) * applied voltage=velocity
I have a question for you.
Do you think the velocity in this equation is imaginary?
If so, what does it represent?
Can you imagine an imaginary acceleration?
If v^2/r was the kinematic (non-dynamic) definition of acceleration, would the acceleration be negative? Against what mass "m" would this acceleration act upon?
First let's setup the equation for mass:
i*(inductance/velocity) * applied voltage=mass
The mass in question must be tied to the particles' (charges) forces and acceleration. Thus it is fair to assume that the masses in question will gain kinetic energy relative to objects of abritary mass upon which it acts. In doing so, it applies forces against these objects causing them to accelerate according to their mass. So what is acceleration?
[i*(inductance/velocity) * applied voltage]/force=mass/force
force/[i*(inductance/velocity) * applied voltage]=acceleration
The mere existence of:
1) force
2) inductance
3) velocity
4) applied voltage
5) acceleration
Make no reference to mass.
What is implied however is that, for a given force, mass increases with:
2) inductance
4) applied voltage
And decreases with:
3) velocity
4) acceleration
Since:
This implies that such masses dissapate over time at they accelerate (which implies motion).
Which variables above can be considered imaginary?
Note that for i=sqrt(-1), when ai=bi, a=b. Also, i^2=1/i^2, and is verified by the fact that i^4=1. It now seems appropriate that we also define the equation in terms of i^2 and 1/i^2
force=acceleration*[i*(inductance/velocity) * applied voltage]
force/[acceleration*(inductance/velocity) * applied voltage]=i
[force/[acceleration*(inductance/velocity) * applied voltage]]^2=i^2
i=velocity/[(inductance/mass) * applied voltage]
i^2=velocity/[(inductance/mass) * applied voltage]
i^2=[(inductance/mass) * applied voltage]/velocity
[i^2]*[1/i^2]=
[force/[acceleration*(inductance/velocity) * applied voltage]]*[(inductance/mass) * applied voltage]/velocity=
[force/[acceleration*mass]]=1
This means out of the variables:
1) force
2) acceleration
3) mass
None of them are imaginary, for:
i=sqrt(-1)
i^3=-1*sqrt(-1)
Euler's formula:
e^(ix) = cos x + i sin x
ix = ln(cos x + i sin x)
The torque of the magnetic field depends on the cross product of the magnetic moment and the magnetic field. Torque varies with the sine of the angle between them.
The energy of the magnetic field depends on the cross product of the magnetic moment and the magnetic field. Energy varies with the cosine of the angle between them. Thus we can state that:
The derivative of energy is proportional to the derivative of cos x, which is -sin x * dx
If torque is the derivative of energy divided by the derivative of angle x, then torque = -sinx
[magnetic moment * magnetic field] TIMES Euler's formula
magnetic moment * magnetic field * e^(ix) = magnetic moment * magnetic field * (cos x + i * sin x)
magnetic moment * magnetic field * e^(ix) = (Energy - i * Torque)
If units of torque * -i = units of Energy, then angle x is in units of -i, and e^(ix) becomes real.
units of -i becomes synonomous with angle.
kmarinas86
Quote from: kmarinas86 on September 09, 2008, 10:09:04 PM
BY KMARINAS86
This is the result of Kirchhoff's voltage laws. The battery is a capacitor:
1) It does not let current through
2) It stores charge at a voltage
3) Voltages can pass through and so can the change of current.
The voltage drop across the battery also consists of a voltage drop due to resistance, which limits the maximum current that can be drained from them. The voltage drop due to the capacitance in a battery is as simple as the battery voltage (applied voltage) itself.
Quotevelocity*resistance*(capacitance/distance) = -1*acceleration*inductance*(capacitance/distance)
-1*power/(change in power/change in time) = inductance/resistance.
This is an often overlooked result. As you will you see, it changes everything about our notion of what "power" is.
QuoteTherefore, as (change in power/change in time) decreases, so does power.
This kind of power is a type of power that cannot exist without changing. It is called reactive power. It results in acceleration.
Therefore:
Thus:
As stated earlier:
and equivalently:
Thus:
Now we know that:
reactive power=-1*[torque*angular velocity*current^2]/[applied voltage]
reactive power=-1*[power*current^2]/[applied voltage]
reactive power*[applied voltage/current^2]=-1*power
reactive power*impedance=-1*power*current
reactive power*impedance/linear charge density=-1*power*velocity
See next.
QuoteWe remember that:
So:
We recall that:
So:
And since:
inductance * acceleration * applied voltage=-1*[force*(current/linear current density)^2]
inductance * linear current density * acceleration * applied voltage=-1*[force*(current)^2/linear current density]
inductance * (change of current/change of time) * applied voltage=-1*[force*(current)^2/linear current density]
It was given earlier that:
So:
inductance * reactive power/magnetic flux * applied voltage=-1*[force*(current)^2/linear current density]
reactive power/current * applied voltage=-1*[force*(current)^2/linear current density]
reactive power * applied voltage=-1*[force*(current)^3/linear current density]
reactive power * applied voltage=-1*[force*(current)^3*/[current/velocity]]
reactive power * applied voltage=-1*[force*velocity*(current)^2]
reactive power * applied voltage=-1*[power*(current)^2]
[applied voltage/(current)^2]=-1*[power/reactive power]
[impedance/current]=-1*[power/reactive power]
reactive power*[impedance/current]=-1*power
From last:
Same result.
Quoteinductance * (acceleration/force) * applied voltage=-1*[velocity^2]
The mass in question must be tied to the particles' (charges) forces and acceleration. Thus it is fair to assume that the masses in question will gain kinetic energy relative to objects of abritaryarbitrary mass upon which it acts. In doing so, it applies forces against these objects causing them to accelerate according to their mass. So what is acceleration?
Since:Because:
This implies that such masses dissapatedissipate over time at they accelerate (which implies motion).
[i^2]*[1/i^2]=
1) force
2) acceleration
3) mass
i=sqrt(-1)
i^3=-1*sqrt(-1)
Euler's formula:
units of -i becomes synonomoussynonymous with angle.
From earlier, we found that:
So:
power/[i*(inductance) * applied voltage]=acceleration
power/[i*(inductance) * applied voltage]=(change in power/change in time)/force
power/(change in power/change in time)=[i*(inductance) * applied voltage]/force
velocity/acceleration=[i*(inductance) * applied voltage]/force
velocity=[i*(inductance) * applied voltage]/mass
mass*velocity=[i*(inductance) * applied voltage]
momentum=[i*(inductance) * applied voltage]
The momentum exchange is proportional to the inductance of the material and the voltage produced
QuoteThe mere existence of:
1) force
2) inductance
3) velocity
4) applied voltage
5) acceleration
2) inductance
4) applied voltage
5) acceleration
And decreases with:
3) velocity
4) acceleration
Since:
Because:
Corrections made.
hartiberlin
Hi,
surely the rotating magnet inside the aircoil changes its
inductance L all the time, so we have a factor of
dL/dt also, which is always forgotten, when a Newman
machine is calculated.
But to my experience, the main electrical OU effect in the machine
is due to oxidation of the graphite brushes and thus the release of free
electrons into the circuit.
Regards, Stefan.
gyulasun
Quote from: hartiberlin on September 10, 2008, 04:37:51 AM
Hi,
Hi Stefan,
Respectfully I disagree: when you insert a permanent magnet into an aircore coil and move or rotate it inside the coil, the coil's L inductance does not change but a very little, practically it is negligible.  The reason for this is that the permeability of any permanent magnet is close to 1 (usually 1.2 - 1.3 (or less) for ceramic and 1.03 - 1.1 for rare earth types).  This sounds suprising for sure. I mentioned this already on this forum too, see here:
http://www.overunity.com/index.php/topic,1988.msg25821.html#msg25821
regards,  Gyula
hartiberlin
Hi,
yes, surely depends on the permanent magnet.
But surely you will also put there in some connection iron
between the magnets, so this might count then also .
Anyway, the dL/dt component is mostly forgotten,
when one calculates these types of motors..so watch out...
