Peltier Generating More Watts Than A Solar Panel
Started by billmehess, September 11, 2008, 06:04:39 PM
TheOne
Great tutorial to make your own dish
PARABOLIC DISH MIRROR PARABOLOID HOMEMADE SOLAR CONCENTRATOR
http://www.youtube.com/watch?v=FZh-CRneIII
pese
MOR SIMPLY the "metering warong" is to unse car lamps as load.
Your "light" is directly comimg to brain and to understand, what power comes out
to load CAR-lamps (bulbs) tha are to find at 5 10 21 50 watt. (12 volts)
after this you can try to understand your "volt/Ampere Meters)
Pese
exnihiloest
Quote from: billmehess on September 11, 2008, 06:04:39 PM
If the same number of peltier squares were connected in series (960) of them the output would be:
960 x 200ma=  192 amps
960 x 20mv  =  19.2 volts
or
w=va     192 amp x  19.2 volts=  3686 watts
Wrong calculation.
As the elements are in series, the voltages add but the current remains the same.
960 peltier squares give 19.2v, 0.2 A, thus P = 3,84 W which is far less than a solar panel of same area.
spinner
Quote from: exnihiloest on September 12, 2008, 05:42:56 AM
Wrong calculation.
Absolutely.
Peltier effect is indeed an interesting thing... But..
Like most of the people already said, the electricity produced is relative to a HEAT difference between the Peltier element sides, and it's perfectly CoE obedient. In fact, it's one of the worst energy converters (in a thermodynamical sense).
Without going into details, I'd say it has at least a few times lower efficiency than a 'same area' solar cell (which depends on different, photoelectric effect).
Check your measurements, use a known resistor for a load and measure voltage across it's terminals.
Ohm's law will tell you the rest.
Cheers!
"Ex nihilo nihil"
