Endless energy from Salt - Magnet
Started by ResinRat2, September 18, 2008, 04:42:00 PM
Tinker
Dave
Yes they do, I was using them in Stiffers wet dialectic setup one inside and one outside in attraction. They pulled just fine I just didn't get enough amps to make it worth the time.
Be well
Tinker
ResinRat2
Quote from: Tinker on September 19, 2008, 02:48:19 PM
Tinker
Great!! I didn't know if they worked through PVC or not. Excellent!!!
Quote from: mdmiller on September 18, 2008, 10:22:25 PMThe jar was so hot I couldn't hold it in my hands.  There was nothing used but magnets.  I don't know if this would work with other salts, I haven't explored it further.
Could you replicate and record this? It seems like a major discovery even at it bases it can at least heat water in a heating installation.
Drannom
amything can be cristallized, almost anything, and then it produces heat, simple and universal
heat is release while cristallizing, usually a chemical reaction
in electrinium.pdf you can get permanent heat or electricity from a special cristallization while putting a lot of volts with a few current in the way to cath energy from the eather
doing crystallization with magnets look like electrinium ( the permanent battery is create by doing crystallisation with thousands of volts ! )
in the Hutchinson topic they work with Rochelle salt...in their compound
any crystallized things may or not transform some Super Light in electricity or heat
i hope this will help to image further
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
