Someone did build a Tricoiler replica?
Started by mikestorm, September 19, 2008, 04:08:11 AM
nievesoliveras
Hi!
I did this alternator inverter thing and I used the LM317 transistor to lower the voltage to 13.8volts so the inverter could function without throwing smoke and sparks.  I could not get overunity though.
Jesus
nievesoliveras
Hi!
The photos of what is left of the experiment are these:
Jesus
mikestorm
after many days of inactivity, i hooked up my coil, and had some problems, that i'm going to explain:
done the bedini circuit(in the trigger circuit i've omitted the lamp and the pot, because with it the rotor went very slow);
done the coil with 100ft of two twisted wire 0.41mm thick;
done the rotor with alluminium, and used 8 ceramic magnet 19x4 mm each;
done and checked all the connections
this is what i've got:
my sistem runs at 423rpm(measured with a mountain bike computer), with 12volts at 0.45(max)amps.
didnt connected the charge battery, but the neon bulb didnt light up.
when i connect a little 12volts lamp 250mA, the rotor starts to reduce rpm.
when i disconnect the drive battery, the light didnt light up.
other things:
the 100ohm resistor is very hot, i've put one of 5watt instead of the 1 watt, but is still hot.
i used a solid iron cilinder instead of the welding rod.
twisted the wire togheter very tight
what i'm doing wrong?
please help me
tomorrow i'm going to post some photos
mikestorm
some news:
i've put a car alternator in the rear of my system, it can speed up to 2000rpm, but when i turn on the car alternator, in order to excite the internal coil to form a magnetic field, the system goes down in rpm and in 20 second +/- it stop to turn.
whats wrong?
maybe is the magnetic field of the internal coil of the rotor is too strong and eliminate the magnetic field of the bedini system?
please help me
mikestorm
