EL IEVE free energy magnetic mill
Started by CLaNZeR, September 27, 2008, 01:37:40 PM
Goat
Hi All
Here is the translation, although there is Spanish running in my veins from way back as well as aboriginal amognst others (you could call  me a Heinz 57 and I wouldn't be insulted!) this translation is from Google  ;D
Interesting though that this is from Juan Carlos Aviles Moran who discovered the cascade of physical phenomenon called magnetic repellency back in 1980!
Exhibition of draft unit magnetic repellency
molecular composition of artificial magnets or alloys (magnetic fields increased or magnified) = torsion strength and speed
Our purpose is the construction and implementation of the new system of alternative energy Repellency Magnetica Unit (MRU) this device) this device due to the simplicity of its structure, it is easy to construct giving a rapid response to the need energy, so limitless, clean and without consumption of other energy that does not come from the same operation.
The MRU was placed in first position on the other alternative means of generating energy, such as fossil fuels, biofuels and blends, the MRU does not pollute the environment, not to lay off toxic fumes, this device uses just two types of various combined forces, which are: the CRM (WATERFALL repellents MAGNETIC) and FC (CENTRIFUGAL FORCE).
Also this project is on the other alternative methods of clean energy such as solar, thermal, geothermal, hydroelectric, wind, marine engineering, and so on. These methods are subject to the variable weather conditions, wear of materials being subjected to extreme temperatures. The MRU has the ability to avoid the erosion of their own pieces, by creating a magnetic field repellency between its major pieces, extending its life by this condition.
DETAILS OF THEORETICAL DESIGN:
The MRU consists of an orbital rim or firmly attached to a base, the diameter of the ring is related proportionally to the size of the shields (ERM) who are predisposed unidirectional in its interior. This succession of shields must all be located in the direction of a single pole, negative or positive.
The magnetic propeller (HM), which revolves subject to its own axis inside the ring, consists of shields at the ends of magnets or face to face with almost rozándose shields predisposed to the hoop, to turn the propeller, the coats of inside the ring as of the end of the propeller must repel each other, ie signs repel them, starting immediately a force of repellency between the coats that make the propeller rotate in one direction, after this initial force begins A second phase of FC that as the size and weight of the shields at the ends of the propeller, will give an increase in revolutions or money orders. This, to provide a force of torque on the propeller shaft that is the resultant force we use to move any motor or dynamo electric generator, staying with the option to obtain a percentage of extra power when connected to return to ring and thereby induce them to the greatest force shields repellency. The MRU has the unique ability of its self-same energy and discharge it into higher energy repellency to the shields.
The MRU is not capable of generating electricity itself, but if you run through the magnetic repellency a mechanical movement which is to rotate its propeller getting a force of torque according to its size, purity and shields percentage of cargo downloading.
CHEMICAL COMPOSITION OF THE MATERIALS
It is important to mention that the basic raw material of which shall be composed our shields reflectors repellents are the iron of high molecular density, some of them being the most suitable manganese steel or steel tuxteno, also known as iron ore stone imam (Fe3O4) as well as those arising from the magnetite.
Shields reflectors, must be manufactured from a high purity metal, to have more repellency when provoke the cascade of magnetic repellency.
This whole exercise is born engineer to apply the laws of physics, molecular and chemical properties that are subject to the materials of the MRU. The MRU emerges from a comparison with the water mill, we will make note that this device is a mill in which the flow of energy is not lost at any time but completely surrounds the mill, closing a circle that we call the infinite cascade Magnetic repellency, which is to be the fuel of the MRU.
Meanings: MRU Unit Repellency Magnetic; HM Magnetic Helix; Aro or Circle; Repellency Magnetic Shield ERM, CRM Waterfall Repellency Magnetic "
"The unit of magnetic repellency MRU created and designed by Juan Carlos Aviles Moran is the alternative means of generating electricity in a very economical the MRU is a mill or repellency magnetic power that turns the shaft of a dynamo. He was in 1980 that juan Carlos Avila moran develops uses magnetic fields between magnets magnified magnetic polarity.
the unit of magnetic repellency MRU mill or repellency magnetic MRM is an alternative to producing electricity and is very easy to build by giving a solution to the energy crisis worldwide, the MRU works with the same principles as a water mill (hydro - Electric) or wind (wind-power) but in the MRU the mill will move by magnetic force repellency (magnetorepelencia-electric)
Juan Carlos Aviles Moran discovered the cascade of physical phenomenon called magnetic repellency this is a unidirectional magnetic force repellency carried inside the rim of the unit of magnetic or repellency mill magnetic repellency, the cascade of magnetic repellency is nothing more than a trail of repellency by continuing where the magnets pass the rotor shaft of the MRU to be repelled by the ring magnets; cascade of such serious repellency magnetic energy shock of water in a windmill THE COMMON "
Regards;
Paul
wizkycho
Hi all !
Quit this setup cause, although it might work for inventor, replication is difficult allmost impossible.
You need exact same dimmensions, most of all exact same strenght of magnets (if not - distances from mags are different)
and material coating... there is no explanation of principle of work.
If it works It is over 100% luck. - when it happens go and play lottery.
Many other things has much more chance of succeeding.
Wiz
Can someone please tell this moron to stop posting the same video over and over again on youtube or get his ip banned on it. This retard is starting to piss me off big time.
yaz
Thanks for the translation Goat!
Can someone ask Juan what the outer ring is made of? Is it metal, plastic or wood?
Also in the translation Juan talks about some sort of shields????  Quote "...consists of shields at the ends of magnets..." On what, the rotor...stator...or BOTH?
Are the shields at the end of the magnets the secret to making it rotate? Sort of a oneway street for the rotor magnets to follow without getting hung up.
Light
You probably rite, Wiz, but what kind of “other things” do you mean?
Thks, Goat.
“…the diameter of the ring is related proportionally to the size of the shields…The magnetic propeller consists of shields at the ends of magnets
- So, we have a “shields” now. Can’t see it on video, but it’s completely different story; PERENDEV has shields too, and angles, and special alloy for shield. I’ve tried something like that (see attach) but not successfully â€" again needa know details â€" what kind of material for shield (I’ve used mild steel, wrong), its dimensions, setup, etc.
Hope with HIS help we’ll get it somehow…
Maybe we need something like that (attach, red color).
