EL IEVE free energy magnetic mill
Started by CLaNZeR, September 27, 2008, 01:37:40 PM
nievesoliveras
Hi!
@Manuel Jose
How are you doing, anything new?
Translation:
Como estas, Algo nuevo?
Jesus
nievesoliveras
Hi!
I found a link that contains a magnetic motor with 36 magnets on the stator and 36 magnets on the rotor that is similar to the magnetic mill from Juan.
http://neo.im/media/document/225.pdf
Jesus
mdmiller
Quote from: nievesoliveras on October 25, 2008, 08:05:02 PM
Hi!
Jesus
incredible - great find, 19.47 is an interesting number.
the following clipped from http://www.angelfire.com/jazz/louxsie/cydonrant.html
"One of the most dramatic and significant numbers in sacred geometry is 19.47. In planetary terms many key energy uprisings occur at or close to 19.47 degrees above or below their equator. Solar flare activity on the surface of our Sun is most frequent and dramatic at 19.47 degrees; the Great Dark Spot on Neptune is at 19.47degrees; and Jupiter's Great Red Spot â€" a dense energy centre â€" is to be found at, you guessed it, 19.47 degrees. On Mars, the great mountain known as Olympus Mons sits at approximately 19.47 degrees. (How appropriate that whatever happened at Roswell happened in 1947!!)
If you imagine a tetrahedron being placed upside down inside the Earth and anchored by its upper point at the South Pole, the top two points would make contact with the outside world at... 19.47 degrees. "
infringer
So you are suggesting that at this position there is a hunk of iron?
OK where is the relevance of 19.47 in this design and what happens at this point?
Please do tell... As this is sounding like a sequel to the movie " The Number 23 "
-infringer-
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
nievesoliveras
Hi!
That pdf comes from this site: http://www.magnetmotor.at/
I just found it on another thread while navigating on the index.
Jesus
