EL IEVE free energy magnetic mill
Started by CLaNZeR, September 27, 2008, 01:37:40 PM
infringer
Is he wearing gloves because it is cold maybe dipped in liquid nitrogen previously to shooting to provide super conduction effects? Possible?
While they are material gloves there could be other gloves underneath it...
Sure he could be hiding something or maybe it is a coverup of his simplistic design to keep it from being stolen...
How can one know without fulling seeing the before and after of everything...
We can not we can only ask and assume we hear the truth.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
nyloncylon
What are those two dark horizontal lines going across the plate just under the ring? Looks like wires ???
NC
ChileanOne
Well, I finally contacted him and we chated over messenger.
It was not easy to talk with him. The man seems to be in a pemanent state of enthusiasm about the fact that, as he claims, the design works.
I asked him since when he has got this working, and said 1990! He says has a running unit 24/7 that he uses to charge truck batteries with an electric fan motor used as dynamo.
He also says that he has much more better designs.
He provided me some clues, as that the magnets he uses are Fe B Nd alloy (that is supposed to be the best magnetic alloy for this motor) and that they are round and from old radios. I asked if they were toroidal field magnets, but he might have not understood, as he insisted the magnets must be round.
He also says the magnets must be overlapped half their distance, he says the magnets don't touch each other even as overlapped, he apparently engraves the supporting ring to allow the overlap without touching.
He said me that I need to use round magnets of 8 cm of diameter and 1 cm thick for the outer ring, and round 12 cm magnets (1 cm thick) for the rotor part.
He insisted that me try it, but I will have trouble to source such magnets. He insist it works and many people has achieved it.
He instructed me to use a fan as starting point, with a stator ring of magnets of the same diameter than the fan blades (which are of course to be removed).
That's what I got pretty much. Will review the msn log to see if something I forgot.
Anyway he says the diagrams that are already in this thread are what all what is required.
Good nights (or morning, is 15 to 5 am down here)
Regards!
Jdo300
Hi ChileanOne,
Now this is interesting! So... by what this guy is saying, I suppose it is safe to say that he has built a rigid version of this motor that allows him to charge the batteries in his truck!?
If anyone is interested in replicating this, I would be willing to make up a set of blueprints that we can all follow (based on the direction of the designer) if he is willing to guide us to build replications.
Just a few comments, it appears that the magnets in the video were ceramic because of their black color. Also, I'm assuming that you meant to say that the magnets are 8 mm in diameter and not 8 cm? The ones pictured in the video obviously could not have been that large.
Again, I'm willing to offer my services to draft up blueprints for a working model that we can all replicate IF the inventor is willing to openly work with us. You can see some examples of my work from the OC MPMM magnet motor saga:
http://www.overunity.com/index.php/topic,3871.msg68853.html#msg68853
and
http://www.freeenergynews.com/Directory/MagneticMotors/OC_MPMM/JasonO/drawing.pdf
This thing looks very simple to make and should be quick and easy to test. I'm willing to jump in on this if we can get some more build details.
Things I would like to know more about:
  • Diameter of the stator ring
  • Type of material used for the ring (plastic, wood, steel, etc...
  • Angle of the magnets in the ring (was it exactly half the magnet face covered, as in (one magnet edge overlaps exactly to the diameter line of the adjacent magnet?)
  • If the magnet faces are not in direct contact with each other, how much of a space is there between the faces?
God Bless,
Jason O
Quote from: Jdo300 on September 28, 2008, 05:12:00 AM
8cm is the diameter of the stator ring.
In my previous conversation I tried to ask him the type of magnetic field of the magnets but it got lost in translation  :P.
Clanzer I believe you were the one that once posted this chart showing the different configurations a cylindrical magnets can have. Could you post that again please?
