EL IEVE free energy magnetic mill
Started by CLaNZeR, September 27, 2008, 01:37:40 PM
Goat
Hi magnetman12003
When you say "I have managed to construct a square shape track that a central pivoting rotor arm magnet can track all the way around 360 degrees ! " do you mean you have a self runner prototype?  If so why not open a new thread and lay all the information down so that anyone can replicate?  Safety in numbers  ;D
You are on a very motivated site to achieve OU so have at er'  ;D
Regards,
Paul
Light
“I need to know if there is anyone interested in constructing this type of experimental motor device…
- Hi, Tom. Well, I’m interested.
It’s hard to understand what do you mean without drawings, but seems it’s more real that el ieve hoax.
magnetman12003
Hi Paul,
No -- its not a self runner yet. It definetely should be one if the rotor is made and positioned correctly. I can go for weeks working that way with no luck. With hundreds of folks trying out different rotor combinations we could have results very quickly.   The square magnetic rail box does send a rotor arm 360 degrees but how high above the track and what strenght of rotor magnet used will have to be determined by experimenting.  Thats where a lot of folks working on this can expedite results.
Tom
Goat
Hi Tom
The only advice I can give you is open a new thread and supply as much information on your setup as possible for peer review that way everyone will at least be able to give you feedback, this thread is for the EL IEVE free energy magnetic mill so just so we don't fill this thread please create a new one so that we can see what you're proposing and we can go from there  ;D
Regards,
Paul
nightlife
 If you all are basing your designs off the first video posted, stop because that only works because they are moving the field with their hand which is letting the rotor keep spinning.
I keep hearing about shielding but shielding does no good unless you are wanting to shield against the whole magnetic field because otherwise you are only bending the field and no matter how you bend it, it will always be a magnetic field which has a equal polarity that can not split and shielded separately.
The only way you can use a magnet to produce energy is to introduce work to it. The problem is that you have to collect more energy from the movement then the energy used to create the movement and that is going to take a very high efficient power source to create the movement and it will take a high efficient pulsed power source to do so.
