EL IEVE free energy magnetic mill
Started by CLaNZeR, September 27, 2008, 01:37:40 PM
allama
Hello again. All the magnets are working on repulsion mode with the rotor magnets. ;)
Dansway
1/2 of the next mag...?  His pic is a little off then....  Hm...
Jdo300
Hi Everyone,
Here's a translation of the images:
LarryC
Okay, Put this together with a few ferrite magnets from small cheap speakers, like the ones you get free with a computer.
All I had was five, the magnets from the speakers are glued into a metal can and hard to remove without breaking.
The rotor magnets has an opposite pole to the stators. Yes, it is in attraction, but in a twisting torque because of the angles. The stators are overlapped to center.
When the rotor is slid just even with the first stator magnet it shoots thru and ending up as in the photo. When sliding the rotor back thru the stator fields each magnet pushes back, but no harder then when sliding pass the first wall to start it up.
Seems to work better than most gates and may not have the problem of becoming one big magnet when the circle is complete.
At this point I would say it justifies farther development with Neo's. I have enough of those (1"x1/8") but it would require that a much stronger be built. I'm busy with another project right now so it will have to be later.
Regards, Larry
