Stanley Meyers Injector Revealed
Started by sirmikey1, September 28, 2008, 10:30:15 AM
kinesisfilms
once again dankie there is nothing wrong with gotoluc......he is working more on a firestorm spark plug method.....which in a sense is a geet processor (plasma based) with water vapor as combustion.
and no matter what you say dankie you need to create unstable particles in order to combust h20 with voltage pressure.....how do you create unstable particles?.....well the incoming oxygen (needed for a combustion) must be turned into a critical state......how do you do this......increase it's energy while decreaseing it's stability......so we remove electrons and ionize the damn thing.....so when it meets the newly split hydrogen atoms it cannot combine and further more creates a very very very unstable particle mixture which is easily ignitable with VOLTAGE PRESSURE........this cannot happen by just splitting water. AT ALL.....THIS IS WHY THERE IS AN ENTIRE SECTION DEDICATED TO THE GAS PROCESSOR IN THE TECH BRIEF.....with the use of highvoltage and photon energy absorption it became possible to ionize oxygen.
stan spends alot of time explaining this photon energy absorption and air ionizer for a reason.....it's the reason why this system replaces spark plugs.
dankie
I know there is nothing wrong with gotoluc , I just hate when people who ignore my pm`s .
I invited him on ionizationx but he snubbed off my offer , he thinks he is too good for us ...
Bruce_TPU
To all of the HHO heads out there,
This link was sent to my email today from a friend.  I thought that I would share it with all of you, as I am consumed (for good reason!) with TPU work.   ;)
Enjoy!
http://rwgresearch.com/open-projects/stanley-meyers-wfc-tec/stanley-meyer-wfc-water-injector-technology/
Cheers,
Bruce
truesearch
@Bruce:
Thanks for sharing that link. Very interesting!
However, it looks like it's beyond what I can do a "garage-experiment" . . .  :-[
truesearch
