To be deleted
Started by nul-points, October 05, 2008, 10:23:18 AM
nul-points
Quote from: forest on January 07, 2009, 02:11:24 PM
Please,if you have the circuit still, could you measure flyback energy when coil in your circuit is exactly inline with Earth magnetic field in N-S direction and then in E-W direction ?
hi Forest
i'll try to check your requested setup when i'm working with this circuit - however, i should point out that my calcs which showed greater energy returned from the coil than stored were mistaken; i used the average current, not the peak current to calculate the stored energy - the corrected values confirmed returned energy equalled stored energy
i realise that you may be interested in the results of your proposed test anyway so i'll try to check that for you
the results used for this thread and in general on my tests with switched charge circuits are all obtained with the coil on a vertical axis
all the best
sandy
dorro1971
hi all,
what about the magnetic component?? could that be used to do useful work and still return close to 100%???
reards
dorro
nul-points
Quote from: dorro1971 on January 09, 2009, 04:32:32 PM
a very good question, dorro, - worthy of a test, thanks!
all the best
sandy
Paul-R
Quote from: nul-points on October 05, 2008, 10:23:18 AM
As I understand it, the official line on fly-back energy is that you only get back what you put in
I don't agree. The collapsing field in a coil is a classic chance to
get zpe energy (viz Lee & Yang, Nobel Physics Prize, 1957 etc)
and is the basis for the success of the Adams motor and others.
It is an opportunity to be calculated for and aimed at.
Paul.
Grumpy
Quote from: nul-points on January 09, 2009, 07:01:37 PM
all the best
sandy
anomolies can be attributed to the "tempic" field, which is the one that is perpendicular to the electric and magnetic fields
        -Frank Edwards
