Magnetic rotar Wind Turbine
Started by glassman, October 06, 2008, 02:02:12 PM
Doug1
Dave
Thats not how the wind actually passes over the bed of a pick up truck. It makes a rolling effect inside of the bed that the air stream passes over. Causing a vacuum behind the cab. You might want to set up some streamers in different places made from ribbon and view the air flows for yourself. That is why a pick up truck gets better millage with the tailgate in place and closed. The friction of air to air is less then air to metal.
  Im not trying to be picky just trying to save you and any other person from wasting time with an inaccurate mental image of the air flows.
Dave45
Hey Doug
You may be right some rnd would be in order, but Im sure you could just raise the hawt until you got maximum torque.
The vacuum created may be to your advantage,
I dont know if vacuum is the right word more like an eddy current.
Dave45
Hope this isnt too far off subject but Iv had this nagging idea for a long time and I need to try it I know, just thought I would share it.
Magnets act like gears if you take a look at the Searl device you will see what I mean, now the Searl device acts like planetary gears.
https://www.youtube.com/watch?v=ECljAo1q1RQ
So if we build coils in this arrangement will they interact.
We pulse coils with dc and ac but how many have tried using straight dc and see if the smaller coils will give energy to the larger center coil.
If the outer coils circumference is smaller than the inner coil it would seem the A vector field would be spinning faster than the larger inner coil.
Will the three outer coils spin up the inner coil.
Is this what Hubbard did.
dave
The Searl device https://www.youtube.com/watch?v=J3W5rblMQsM
Dave45
Something else I forgot to mention, when I was freezing coils I noticed the A vector field in an air cored coil ran outside the coil but the field runs tight up against the core if a ferrous core is added.
So if the outer coils are air cored and the inner core is ferrous will the outer coils give their field to the inner coil.
