Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
silverfish
Quote from: forest on February 19, 2010, 04:50:39 AM
Not needed. Look at Kapanadze device. Large DC voltage difference between ground and elevated capacitance makes a pump of displacement current - it's like a underpressure. There is overpressure on elevated capacitance. The spark is very energetic in amperage ! All we have to do is to know how to convert that current into normal one and it will become a valid implementation of Tesla idea of unanimated device working continuously on ambient energy.
This is where bifilar coil can be used IMHO. Kapanadze found actual shape of coil which converts unidirectional speed-up displacement current escaping as spark from Tesla coil into large current  high frequency in closed circuit.  Look his 100kW unit in video : 3 TC coils are clearly seen sparking into 3 special coils (receivers)
There is something about bifilar coils which needs further research. Depending on the windings, you get different results, but according to Tesla's patent you can greatly increase the capacitance of the coil, and hence the potential energy.
      It's been suggested that if you took Bill Muller's generator coils, with  the amorphous magnetite/resin cores, and replaced them with correctly wound bifilar coils according to Tesla, reproducing Muller's system under these conditions, it would be interesting to see what happens.
Tito L. Oracion
Quote from: forest on February 19, 2010, 02:19:47 AM
Excess coil or extra coil in Tesla magnifying transmitter produced extremely huge voltage when oscillating freely. It is the analogous of whip  or swing. Now we call it antenna.
The solution is clear ! however essential part is missing.
Tito is using extra coil to generate extreme voltage from small power source, but he found a way to use it as a pump - sucking displacement current from ground or air and generating current spikes. Apparently it is not easy because we are misled by current knowledge about power in antenna being not real.Correct - it is reactive most of the time, but I'm sure there are ways to make it dissipate power into envinronment.
Read Colorado Notes - Tesla suddenly found that sparks from elevated capacitance of his magnifying transmitter can reach thousands of amperes.That was  surprise.
@forest
YES! bingo you are absolutely correct with this quote!
@bar
of course the many the extra the many the gain but be very careful if you are using thick wires with caps cause it will make you fried and crunchy  ;D
and sometimes, a sudden and unexpected lightning is produced in the near of you so be very careful sir!  ;)
better wear many aluminum with magnets insulated to you to save you from this funny but dangerous experiment  ;D
Bye friends AND God bless and BE VERY CAREFUL CAUSE YOU WILL NOW PLAYING WITH LIGHTNING OK  ;D
Tito L. Oracion
Quote from: silverfish on February 19, 2010, 05:01:43 PM
good!  ;)
Tito L. Oracion
hi every body gooday  ;D
i will now congratulate you cause you are all already there, anytime now one will figured it out.
or anytime now one will go to other dimension of life  ;D
That is why be careful!  >:(
This experiment is the critical moment. its a matter of life and death.
do your experiment far from your family and others family!
make a long wire switch ok!
Magluvin
Good going Forest.
I see many setups on YT that have a transmitter and receivers lighting LEDS and some lighting light bulbs on the receivers.
What I would like to understand is why the whole super high voltage? In teslas later days after the tower was torn down, he made receivers that didnt need transmitter, it ran off of what was already there. He also stated that the voltages were much lower than what the transmitter/receivers would use.
So My idea is to get some coil/cap configuration that works at lower freq and voltage. Resonance is resonance at what ever freq or voltage. There has to be a safer way to do this and make it compact.  I am not attracted to aluminumfoil clothing or the every once in a while lightning bolt action happening. BAP BAPBAP!
Even if Tito did show all, I would still use that knowledge to work smaller angles of the process. Big is great. If I had a setup like Titos, I could charge my electric bike, run my tv, lights. But they could all just have smaller versions built in. If I were to ride my Ebike across town 20 mi.  I would need a recharge, and maybe no place to plug it in. So if a small version that doesnt even need to put out what it takes to run the bike, just enough to charge as normal whenever the battery is lower than full. Even that small amount would be enough to extend the trip, and at every stop or release of the throttle, its charge time. So if it was able to put out 1.5a at 48v. (60v full charge max) I would have the same charging time more of the time and never left stranded. Stranded, on a bike? Its 80lb itself, Im 220lb  peddling 300lb around 20mi is not a treat on the street. Just being on the bike for almost 2 hours a day can take a bit out of you. Lance Armstrong Im not  =]
Mags
