Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
Magluvin
Hey Tito, I did it!   And its running my bike!
Oh Happy day!   ;D
Mags
Edit  Do you think I need more coils or bigger ones?  =]
forest
Quote from: Magluvin on February 22, 2010, 05:56:43 AM
Oh Happy day!   ;D
Mags
No. All you need is to make special configuration of coils to make Kapanadze pump works in whirl fashion. This is what Tesla (1931),Hubbard,Mark,Smith and others did. Sorry Tito, this idea is not really yours.
One method is by creating environmental electricity pump, the other evolved from this by putting energy back into system and allow to flow in circle which is the best done with special coils but Kapanadze also shown it's possible with ground system. The second method is taking electrons from air.
I'm not sure yet if there is a third method also but it seems be realizable. The third method uses only radiant energy and atomic spin of metal atoms. This is the best method and allow truly miracles (like converting anything into anything).Not sure if anyone is ready for it.Tesla howitzer.
Magluvin
Hey Forest
Hows it going?
So where should we begin here?  Have any idea what to look at to give some good direction?
Mags
Tito L. Oracion
@ all
we have a lot of ways to control voltages and ampere and you know that already ok.  ;D
300 watts of power is enough for a bike to run, just a good configuration of the gear gives you an energetic bike like the 369 gear configuration style ok. so that the motor will not suffer for heavy loads.
start DIRECTION suggestion: read hendershot papers.  ;)
                        and MAGLUVIN, SPARK, WATTSUP, FOREST and erfinder POST  ::)  ;D  ;D  ;D
@FOREST
well i admit the idea is not mine its really from tesla but we are not many that knows the simple technique.  ;D  ;D  ;D  ;D  ;D
Magluvin
Na Teets. This bike uses a brush less motor in the front wheel. Your at 25 mph in less than 10 seconds. And the bike and me are 300lb. No gears here. The motor has like 60 1.5in x 1/2in. x 1/8in. mags on the outer drum and the coils are stationary to the hub. A lot of the pulse motor stuff we work on, we should be just be using this and modifying.
The max power in the US is 750W and 20mph to still remain a bike by law, except cali where they allow 30mph and faster with registration and tag.
At 500w I am getting very good power for up to 20 mi. depending on the stops and go's. Acceleration takes the most out of it, once going its not using 500w at full speed and throttle.
But it would be cool to be able to go and go and go. The bike has been very reliable, rain and all. I have 3 of them and 2 cars. But I ride the bikes a lot.
In fact I could make a different controller that paused a bit between pulses and capture some bemf. It could add to the ride being that the bemf is only discarded normally. Might loose some power with pauses, but the power I would get would go further.
Mags
