Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
baroutologos
QuoteFrom Forest
Not needed. Look at Kapanadze device. Large DC voltage difference between ground and elevated capacitance makes a pump of displacement current - it's like a underpressure. There is overpressure on elevated capacitance. The spark is very energetic in amperage ! All we have to do is to know how to convert that current into normal one and it will become a valid implementation of Tesla idea of unanimated device working continuously on ambient energy.
This is where bifilar coil can be used IMHO. Kapanadze found actual shape of coil which converts unidirectional speed-up displacement current escaping as spark from Tesla coil into large current  high frequency in closed circuit.  Look his 100kW unit in video : 3 TC coils are clearly seen sparking into 3 special coils (receivers)
I received today a small digital NST for automobiles that has the following specs: input 12-15Vdc, @5 amps max. Output 9500 volts @ 30mA. (Don Smith suggestions to experiment with those)
I assebled a small run setup with an improvised magnetic quenched spark-gap.I charged my ready 26nF cap bank and fired at several distances of the spark-gap. All ok. The interesting part is that in an "arc short" or when the NST enstablishes a conductive path on air, the streamer that is should be close to max nominal amperage of 30mA is quite thin!
The spark will jump of a small distance, more or less 1mm and will be thin!
I had not idea how much streamer thickness will correspond to amperage, but seeing the specs and comparing to my Solid state Tesla coil (Kacher) i can say that the TC is able to produce, constantly, at least to the eye, streamer far more long and thick.
Longness of course correspond to voltage. I estimate on the topload of my SSTC to have 40-60KV. But, it thickness is serious more than the NST. Can be 5-10 times as thick...
Is that a virtual power, the streamer, corresponding to just resonance standards or can be tapped in any way, as the videos of Kapanadze showing streamers issuing from a coil to the next??
Magluvin
Logos
Sweet spark gap setup dude. How is it going?
Mags
Tito L. Oracion
Quote from: Magluvin link=topic=5772.msg229910#msg229910 =1267005217
Im not saying electrons are being produced, they all already exist. But the action of the way Teets is manipulating the force is causing more power to flow than can be produced with input alone. I dont know how.
The new OU prize candidate is giving his new transformer to the ou crew. Maybe this will be something that is easy and everyone gets a slice of pie.
Some one will give away the goods at some point. Then most that have been holding on to it will just have to sit back and say hmmm.
Mags
yes they(electron) already exist, we 're just controlling them right!
Magluvin
oh  Logos
tesla used mica in the surface of the mags and they can be brought in very close to the gap without the spark jumping to the mags.
Mags
baroutologos
Thanks Mag for the Tip. Actually the near neomagnet to the arc is form epoxy. BTW that does not stop the conductivity to go over the epoxy if voltage mounts above a level (10Kv).
Mica huh..
By the way, the spark gap of a semiclosed magnetci circuit form neos, have an ear-splitting feature. I am pleased! My next will be from huge neos 100kgr + of attraction.
