Tesla's Magnifying Transmitter (amplify electricity)
Started by sirmikey1, October 07, 2008, 10:32:59 PM
Magluvin
Logos
Didnt Tito just post that he didnt have an answer about the bifi above? But now you say he said this of trifi?
Can you refer me to that post please?  =]
I just think it is strange.
thanks
mags
baroutologos
you are not paying attention... ;)
http://www.overunity.com/index.php?topic=5772.165
scroll down until you spot the comment of what kind of coils he says he uses.
I think, he refused to reply because i made the mistake to call his "tits" instead of "teets" :D Sorry my colloquial english sux.
Anyway, we cannot name with such an ease the biffilar coil as a magnetic amplifier! Magnetic field equals energy. And since the biffilar works better with voltage, i am thinking if the concept about the biffilar holds true, then we should discharge to it large voltage / current and see....
I was grasping the concept, that biffilar perhaps should radically differ from a coil scheme connected in series with a capacitor. If a capacitor is connected in series with a coil, still the inductor have the chocking action/magnetic field build-up upon the very first discharge or current rush, whereas the capacitor poses no impedance.
May be that the biffilar poses no impedance or lesser at least from an ordinary coil, so increased current so increased magnetic field, so increased energy harvest?
We need to investigate towards this direction..
EDIT:
An interesting observation made in the infamous Kapanadze video of Turkish back-yard free energy presentation. (perhpas it has been said before, i do not know)
In the end of the demonstartion, all fellows went inside a home and some books and papers were shown based on the technology. For those having the full . video, at the 53:13, a guy next to Kapanadze holds a paper clearly shown an article of Oliver Nichelson in 1991 talking about Tesla's energy designs and the biffilar coil.
http://home.earthlink.net/~drestinblack/generator.htm (see the article here)
In case they are not genuinly mislead us, they leave a lead?
delboy
Why are you expecting someone to tell you secret??? Why are you focusing on bifilar when it is designed for coils for electromagnets not for TeslaCoil? Tesla newer draw any bifilar coil for Tesla Coil! Ask Tesla ! You are speaking about some receivers but no one is mentioning Tesla longitudinal voltage receiver like in patent 685955 or in 787412 !
Problem in working that receiver which is not sensitive one, is that you need to create big enogh disturbance in Earth. How to do that?? Well build one TeslaCoil like he had one :D You have to have HIGH VOLTAGE AND HIGH FREQUNCY to have enough voltage per meter of length so you can operate receiver!
If you don't want transfer throgh Earth but only localy over some wire, just connect transmiter directly with receiver.
Everybody are building some TeslaCoils and when you compare them with Tesla they look stupid!
For example, everybody are building TeslaCoil with secondar with several thosand turns and diameter max 20cm but Tesla had one with 50 turns spiral wound and diameter 244cm and developed 2-4 mega volts, and compare that with results today in TeslaCoil practice :D You have wrong instructions for TeslaCoil !!! His secondary was cable No8 or diameter of 3,2mm giving 8,3 square milimeters and having resistance only 2 Ohms per kilometer of length! Compare that with todays TC with secondar with wire No32 or diameter 0,2mm having resistance 538 Ohms per kilometer length! How can you have AMPLIFICATION if resistance is HIGH. AMPLIFICATION is Q factor of coil which is inversly proportional to resistance !!! When it was no longer practical to give rise to diameter of wire Tesla introduced cooling the wire to very low temperatures (-200°C) to have even bigger AMPLIFICATION because resistance is falling down with temperature (see patent 685012)! His primary was only one turn cable consisting of 37xNo9 giving aprox 244 square milimeters! How can you than expect to have good working receiver if you don't have good transmiter?
And one message to ERFINDER : Thank you for everything you pushed me in right direction, I can drive now by my own.
bboj
forest
Look at the picture.3 TC are clearly visible.Those 3 receiver coils are the SECRET ONES, but Kapanadze described them as bifilar made. They are good for electromagnets, right ?
How they work separated from power source by a  spark gap ? Pulsed magnetic field right ?
What if the secondary one terminal is connected to primary bifilar end while other bifilar end is connected to spark gap ? The electrons from spark will push electrons inside wire and finally push electrons in secondary thick wire while magnetically producing power.Hmm....VAR correction ???
