"Axial Flux" Concept
Started by Oxygon, April 04, 2005, 08:10:08 PM
0 Members and 37 Guests are viewing this topic.
Oxygon
Here is an idea I had a good while ago...
http://www.besslerwheel.com/forum/viewtopic.php?p=6826#6826
the basic idea is...
the inner magnet is always in position according to the inner circle field polarity... (varies by design)
the outer magnet acts as a "lever" and twist the arm to the closest possible outer field proximity...
when it gets to close, the inner magnet "shoots" accross to the other side... changing the "axis"...
Also the momentum of the whole thing wipping around would overcome any inhibiting forces...
Please feel free to respond...
_________________
PMM Designer/Inventor Extrodinair ;P
TechStuf
Quite novel approach but it has an achilles, or should I say 'peregrinus heal'.  In this case, your perceived leverage advantage actually helps hinder efficiency.  But with your level of creativity I wouldn't be surprised if you find some interesting new concepts hidden in the model you have there.  Build it and see.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
Looks pretty interesting !
Are there also at the outer rim magnets ?
Or is it only a rotating  mass ?
The inner magnet "switching" axis change is very
smart ! Well done !
Looking forward to see a built model.
Yes, I think, only with the help of magnets could a
"gravity wheel" be built !
Regards, Stefan.
BushWacker
Hi Oxygon,
    I don't want to sound like a knowitall so please don't take this that way okay?
It's just that your idea looks similar to something I tried many years ago, except by using very fine circular gears. I placed a ring of magnets all in opposing mode, eg; all alike poles faces inward. Then I used a piece of hard sturdy plastic which I drilled a center hole in, over the magnetic ring assembly. Next I placed the larger of two small plastic gears dead center on a metal axial which I set in the center hole.  I then took the second smaller gear and fixed an arm to a smaller metal axial which was placed through the smaller gear, and fixed the other end of the arm to the center axial of the larger center gear. I then took a simple popcycle stick, drill a small hole in the middle of the stick, and placed a single magnet on one end of the stick. By barely moving the popcycle stick, the single magnet would sometimes spin all the way around the ring assembly with quite a bit of velocity. I always thought that if a person could use the initial centrifical force of the moving magnet on the stick, and perhaps use a very light spring or flywheel which would capture enough intitial energy from the motion of the single magnet, that one might be able to keep the thing going indefinately. It's not far off from what your showing there from what I'm getting from your animation. But, I could be reading it wrong, I have been known to make mistakes from time to time, lol. Keep up the good fight my man.
Cheers,
Bush Wacker
joecool
The Sundance Generator is obviously a scam.  Anyone who has taken Physics knows these claims of generating excess power is just not possible. Don't get me wrong, I wish it was possible, however it is just untrue.  By basic laws that govern the world as we know it you can not create matter or energy! Therefore, given the laws such as conservation of momentum, energy, and matter these free energy concepts are just not possible. You can't create something from nothing. You can even think of it this way, the friction that would be generated as a result of magnetic force turning the shaft would eventually bring the rotation to a halt. There is no 100% efficient motor on the market because that's not possible either. Even if there was you would still have friction from something (et. air)!!! I don't mean to be a party pooper but it?s the truth. If you want to try and invent this stuff then I suggest you start reading up and beware of the rules in which you must follow to play the game.
Engineer
