Awesome Discovery or Simply disinformation?
Started by Magnethos, October 11, 2008, 06:39:13 PM
Magnethos
Quote from: pese on October 12, 2008, 08:31:21 AM
The output voltages (from Supply Plugs)
is it  DC  (VDC)
or AC (VAC)
this must be very different in the application....
but in both way , very suspect
GP
Sorry, I didn't show all the information
Wall Adapter 1: Input 230VAC 50-60HZ Output 9.5V @ 0.55A
Wall Adapter 2: Input 230VAC 50-60Hz Output 24V @ 0.29A
Magnethos
Here you have the 2 adapters:
P.S I don't know if the 24 Volt is AC or DC.
seems to be AC?
Magnethos
uhmmm...  >:( it seems that the fan doesn't works well...
Magnethos
Result: disinformation
It seems that the motor fan is broken. I get the same results using only the 2 wires from the wall adaptor 9.5V@0.55A. When I connect the third wire the system maintains the same speed. So... maybe the effect is because I have conditioned the fan motor changing the voltages or... I don't know.
Too much easy to be true  ;)
I'm going to think in the next experiment...
