Why not aluminum?
Started by Farlander, October 14, 2008, 10:51:47 AM
Farlander
Here's the circuit I used with the LM324.  Using all 4 op amps, you can make a really clean square wave up to abuot 7-8khz.  Using just one op amp, you can make a crappy sawtooth wave up to about 40khz, and if you had a driver you could switch a mosfet.
This chip is strictly PWM, but it does do 0-100% duty cycle, although the max frequency is low, 7khz
I'm going to build the 555 timer and tinker with the components.  I think with a 5+megohm resistor you could really expand the range of the 555.  I was thinking of putting 5megohm pots in where every pot is in the Lawton circuit, and power it with 24V not 12V, would that work?
professor
Quote from: pese on October 23, 2008, 02:42:44 PM
@Professor
Reference to:
Lie #2 : Dr. Milbank Johnson compiled Rife's work and was reported to be preparing an announcement on the "Cure for Cancer." He fell suddenly ill and died shortly after being admitted to a hospital in 1944. Federal inspectors in the late 1950's - early 1960's concluded that Dr. Johnson was most "probably" poisoned.
Answers:
http://www.google.de/search?hl=de&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=followin+emails+contains+spyware&spell=1
http://www.google.de/search?hl=de&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=Dr+Milbank+Johnson+murdered+poisoned&spell=1
nothing is impossibel
to cover any true - is als possibel.
Tesla murdered 1943
you can als ask google,com
Nothing is impossibel,
if great money stand behind
The GOOGLE answers are an Part of good askings.
GP
Hi Pese
Nice to be able to say hello
I had been out of town flew to Vancouver to pick up a car ansd once more a week later to pick up a 4x4 since I sold my Rav4.
Its only an hour flight but 10 Hours by Car,turned 67 today and its a bit strenuous.
Anyway I am back and the work on the Cars has already begun,you guessed right Used Vehicles at a good price but needs fixing if you are fuzzy like I am.Anyway thank you for that info I knew that vaguely as I ignored those Details and I did not get back to that Jerk to give him any satisfaction.He is like a bad cold that eventually goes away by itself.
Thanks again Pese
Hi Jeanna
Regarding the Aluminum and switching  I see what you mean just to prevent corrosion it can be switched once every hour using a 555 timer and relay.To fast of the switching behaves like AC and is counterproductive as AC does not split water just boils it.
I did also do my experiments using rods in a small glass jar, where you could observe any quick responses to the changes one makes.
As I always stated the Alu gave off more Gas then the stainless with or without KOH .
But is it the Answer? I am currently busy with my two Cars and Experimentation has to be put aside for a while.
I am sure that we will have snow soon and it will be to cold in the Garage thus giving me time to retreat to my workshop inside.
professor
