Bedini SSG puts out 800 volts using auxilary inductors!
Started by supermuble, November 02, 2008, 08:43:07 PM
supermuble
Ha ha! I am new to circuit diagrams, and I didn't draw that portion of the diagram. I have NO idea what that is! I guess for now we will assume that it is an "optional" coil that isn't needed!
nievesoliveras
identity
thanks supermubble for the diagram. I have seen you also at the energetic forum huckmubb. :)
so its a bifillar coil. How to connect if it just a single coil? can you draw onother diagram please. thanks.
pese
Quote from: identity on November 05, 2008, 01:34:27 AM
ich habe niemals und nirgend eine Schaltung gesehen, bei der die Ladespannung über 13 volt gekommen ist !.
Ein 12 Volt Batterie muss mit 14,2-14,4 volt geladen sein , nur dann ist eine Batterie  ( nahezu ) 100% geladen.
Pese
I have never and nowhere seen a (BEDINI) circuit in which over 13 volt charging has come!.
A 12-volt battery with 14,2-14,4 volt must be loaded only than a battery is (almost) 100% loaded.
Pese
pese
Quote from: nievesoliveras on November 04, 2008, 11:26:36 PM
Hi!
Pardon my ignorance, but I dont understand the extra coil on the trigger circuit.
Jesus
In this design , shown that is only "forget" an connection ...
But to trimm the base current of transistor with an 25 ohm an an additional
5 K-ohm trimm-pot is serie is "very unusual" (expressly "nonsens"
Pese
