Fuel Vapour System - Got it working!!
Started by plasmastudent77, November 08, 2008, 02:11:48 AM
Mark69
True, you vehicle should be the easiest to convert.  If you can get the fuel vaporizing, you can run it right to the carb air inlet.  the air/fuel ratio you are shooting for is about 12.7 (air) to 1 (fuel).  For example, if you have 14 hoses, 13 of them should flow air and one flow gas.  Now that would technically give you a 13 to 1 ratio, which is close.  Then you could take one of the "air" hoses, and make it slightly smaller (have it 7/10 or almost 3/4 of its original size).  That would get you right where you need to be.  Now, you need the air in all the hoses to flow at the same rate as the gas, so all are equal.
The hardest part for you will be to get the gasoline vaporized then have the outflow of that equal to the air.  Just remember if you have any gasoline "gas" under pressure, it will be explosive to have a safety pressure relief valve in there so you don't blow up!
Hope to hear how you guys are doing!
