A SQUARE MAGNETIC RAIL -- ROTOR 360 ROTATION
Started by magnetman12003, November 15, 2008, 02:45:46 PM
AB Hammer
Quote from: nightlife on November 16, 2008, 08:30:53 PM
Are you serious? You mean to tell us that you did this and cant remember how you did it? It would be like the first time you had , a very unforgettable experience but yet you say you forgot?
nightlife
My father poo- pooed what I did for I was being a dreamer and I needed to think a real job because inventing was a waste of time. Unfortunately that is what I remember the most for under my father I could do no wright, and my older brother could do no wrong.
Alan
magnetman12003
Hi,
This may work as both polaritys of the rotor are not on the same plane as the box track. In this case only the south polarity of the rotor is being powered by the track to move.
magnetman12003
Hi,
I just have to ask this.
How many folks are in the process of actually building this setup to give it a try? It wont cost an arm and leg. Ceramics blocks are inexpensive.
Tom
AB Hammer
Quote from: magnetman12003 on November 17, 2008, 10:44:26 AM
Hi,
Tom
Greetings Tom
I am doing it. I only need about a dozen more magnets. Besides this project may jog my memory.
Alan
nightlife
 I have been trying to figure out the field you have created and I come to the conclusion that you have created a upward and downward spiraling cone like field like pictured which will not work with using permanent magnets for the rotor unless it is allowed to rise up a pole in a spiral motion and when it reaches it upward pressure limit it should bounce back and forth from the downward draw of gravity. If you apply a pressure from the top, the pressures will stop the rotors motion. If I am right, a three pole rotor should work and I would suggest having the spiraling rotor bounce up and down in side of a double wound coil to collect both current that would be created. The field will have to be strong enough to over come the initial gravitational draw back pressure. Another possibility would to have another box placed above one with the spiral effect rotating the opposite way. The rotor should then continue to turn but yet stay stationary within the upward and downward pressures. I would also suggest having one box’s corners placed over the centers of the rails so they are offset from each other.
Your video proves what I am saying by the way the magnet spirals in a outward motion pushing the magnet up and out as it spirals.
