A SQUARE MAGNETIC RAIL -- ROTOR 360 ROTATION
Started by magnetman12003, November 15, 2008, 02:45:46 PM
magnetman12003
Hi Guys,
While we are thinking about this go back to reply 26 and look at the box track video again. Especially the repel portion of the video. where I had the end of a long stacked rod inside the box track.
Something hit me last night and I have to draw it out to show you.  I finally believe that this simple idea will work as now we will have GRAVITY working for us.
Say you were balancing a long pole on the end of your finger at a given height off the floor.. Now the top of the pole starts to fall away from you. Without changing the height you were holding the pole off the floor how would you try to regain balance once more?  By chasing it--Thats how.
Now figure we had a two or three arm rotor with "one each" long stacked magnet rod hanging from all arms and free to rotate on the arm.
The rotor arms would spread out due to box track repel and the top of the rods ( weight) will lean into the rotor arms causing them to turn by gravity assist.  I am going to give this a try also.
Tom
magnetman12003
Quote from: magnetman12003 on November 22, 2008, 09:42:35 AM
Hi Guys,
Now figure we had a two or three arm rotor with "one each" long stacked magnet rod hanging from all arms and free to rotate (hinged) on the arm.
Tom
nievesoliveras
@magnetman
You are spreading yourself too much. Stick to one model.
I thought you got it all planned.
Jesus
Waltzing Matilda, Waltzing Matilda
You'll come a-waltzing, Matilda, with me...
and he sang this song
as he walked along the billabong...
Those who do not remember history, are condemned to repeat it...
magnetman12003
Quote from: nievesoliveras on November 22, 2008, 01:27:19 PM
@magnetman
Jesus
I am and making use of anything the magnetic box rail setup might be capable of doing.  Take away the corners problem and a SMOT could be developed.  I am doing that also.
In the meantime I am also going with what is stated above. Simple to try -- IF you have already made a magnetic box rail track like I know LIGHT  has done.  NIGHTLIFE is working on the SMOT idea also. Hs anyone else started on this or waiting out results from others?
Tom.
