A SQUARE MAGNETIC RAIL -- ROTOR 360 ROTATION
Started by magnetman12003, November 15, 2008, 02:45:46 PM
magnetman12003
Hi All,
After 30 years of making various all permanent magnet motor devices I have designed something that should work. All previuos model devices I made did not function. This one functions to a point but I need help designing a  rotor.   I figure a hundred or so different folks working on this could expedite a self starter motor device.  It would take me a lot of time doing that myself. All I want is credit for the magnetic box design that I will show you after I downsize the completed magnetic box structure I have been experimenting with.  I will post a jpeg of it here then.
Shown is a SMALL rotor with 5 arms on it in the center of the magnetic box design.  It does not turn because the powerfull magnetic forces inside the box completely envelopes the whole rotors south and north poles.  All North poles on the rotor arm tips face the insides of the magneti rail box.
Clockwise rotation comes by making a rotor leg very long and raising it at least 6 inches or more over the box track and thats another story.
The long rotor leg will turn 360.  This is where experimenting by a lot of different folks can expedite rotor development.  I believe a long cone or spiral shape rotor will work but that is only my idea at present.
No-- I have not achieved a self starting fully operational motor but I think my magnetic rail box is a good place to start.  When I post the jpeg photo of this magnetic rail box  device you will see it color coded. Reds are north ends. Blues are south ends.  The rail design and polaritys---- "MUST"---- be constructed as pictured. Any other way the box setup will not work. The insides of the square box has the magnetic flow going in a single direction on all 4 rails.
The corners of the insides of the box are what I would like to call transitional areas. They are not sticky spots and can be easily powered through because 4 out of the 5 rotor arms will always be on the magnetic track while 1 arm is pointing at a corner area.
I would like any person who finally makes a suitable turning rotor to post it on this web site for the world to copy for free.  I am not into this for money or fame. I just would like to be recognized that I designed the basic magnetic box setup given to all for free.  I also plan to make a movie and place it on The U tube so you can get an idea of what I am talking about.   Will do that and tell you where on the U tube you can view it later
Who is interested?
Tom
Light
Thks, awaiting for materialised thoughts:) ("When I post the jpeg photo of this magnetic rail box...").
magnetman12003
Hi All,
Here it is.  Make it with stock over the counter ceramic blocks EXACTLY as you see it.  Otherwize it will not work.  Red is a North polarity end and blue is a South polarity end. Note: The box covered up with wood is the first one I made but it is made the same way as the others.
nievesoliveras
@magnetman
Does disk magnets work? I ask because I have about 20 left from other projects.
Jesus
magnetman12003
Quote from: magnetman12003 on November 15, 2008, 05:11:41 PM
Hi All,
Here it is.  Make it with stock over the counter ceramic blocks EXACTLY as you see it.  Otherwise it will not work.  Red is a North polarity end and blue is a South polarity end. I painted the 45 degree wood support blocks to show that. Note: The box covered up with wood is the first one I made but it is made the same way as the others.  I now included a colored drawing.
Notice how the magnets rails line up in the corner areas.  Use block magnets. I have not used round magnets. The magnets must be staggered just like you see them. The magnet ends are 90 degrees apart  NO AIR GAPS  between the magnets.  In my setup I used 3/4 inch thick magnets. So my staggered end triangles were 3/4x3/4x3/4 inch.    Also shown in my drawing is a 3 arm rotor. 5 arms should work better.
Tom
